Anyone debate buying vs renting a pressure washer?
   / Anyone debate buying vs renting a pressure washer? #11
I had an electric Karcher that, when it worked was OK. But it died after two years and in the interim I had to struggle with the cord and hose that kept trying to wind in a different manner than I wanted them to. Plus it was difficult to connect the hose. I had to drag it inside for winter and those memory cord issues were always in the way.
And here I was going to suggest getting an electric Karcher... Oh, well. Mind you, I knew what I was going after (brass internal) 'cause Karcher is the brand that the Air Force (RAAF) uses to wash-down their aircraft. Of course, our winters are nothing like what you experience.
Mine is still going strong after 3 years.
I think they make different quality levels as well so I might have got a lower end unit. Just struggling with those stiff and windy cords was a challenge but I thought it did a good job.
   / Anyone debate buying vs renting a pressure washer? #13
G'day they certainly do have two levels of machine we have one here at our workshop and it is a hot wash as well it would see 4-5 hrs of use every week and is over 15 yrs old and the only thing we have had to replace is the odd o ring here and there, mind you the replacement price for the same unit is around the $4.5k mark
Jon
   / Anyone debate buying vs renting a pressure washer? #14
I've had a homeowners grade PW for several years. I run it out of gas everytime i use it and blow out the water through the pump. Never an issue starting or running. Not a fan of renting.
   / Anyone debate buying vs renting a pressure washer? #15
I just got a new electric power washer. It is not the most powerful but it world to wash the tractor and everything I need. I only paid $135 or so for it so I break even if it lasts 2 years and I come out ahead if it lasts 3. Can't remember the brand but it works well. Ed
   / Anyone debate buying vs renting a pressure washer? #16
My first one was a Sears unit, it lasted about 5. Years than the pump went. I replaced it with a Dewalt that has a Honda motor. It's probably 5-6 years old now. I think it was 800.00 +\- when I bought it. I would much rather own than rent,simply for the convenience factor. I have in the past hooked it up to my hot water valve so it would be a "hot water washer" Doing that helps a bit, but if I buy another one it will be a real hot water one.
   / Anyone debate buying vs renting a pressure washer? #17
I have a Simpson 2600 PSI unit that I bought 16 years ago and it still works fine. Motor cranks on first or second pull because I let the tank run dry everytime. Winterizing consist of pulling the starter cord a few times to pump the water out of the pump and draining the water from the pressure hose and wand and that is all I have ever done. Even with the -40F winters in Canada, it has never damaged anything.
I am not a fan of renting equipment when you have even a yearly use for it. Properly cared for most equipment will last you more than 10 years.
IF it is a one time use, then renting may be OK but rarely have I needed anything for just one time. Repeat occurrences of "one time need" seem to happen to me all the time which is why I need 3 tool boxes and a 44x52 shop to store all my tools and toys.
   / Anyone debate buying vs renting a pressure washer? #18
I'm not a fan of renting. I probably use my PW about 5 times a year so renting wouldn't make sense.
   / Anyone debate buying vs renting a pressure washer? #19
15-20 year old Craftsman 2100psi with a Briggs. Use it all the time if you have one. Wish it was electric for winter storage but oh well, as long as he keeps on chugging, I'll keep him. I wouldn't be without one tho.
OK, great advice. I'm now looking into buying and if I find something will get the details and report back. Thanks all.
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
7ft Adjustable Scrape Blade (A51573)
7ft Adjustable...
2012 SOUTHERN VAC  130 BBL STEEL VACUUM TANK TRAILER (A52472)
2012 SOUTHERN VAC...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A52576)
2015 VOLVO VNL...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
