John_Mc
Elite Member
- Joined
- Aug 11, 2001
- Messages
- 4,573
- Location
- Monkton, Vermont
- Tractor
- NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
I recently had a log grapple added to my FEL. This required plumbing a hydraulic line from one of my rear remotes to operate the grapple. I asked of they could put some kind of elbow on the quick disconnect from the new hydraulic lines, so they would stick out too far to the rear (I was concerned that the connections not stick out far enough that they would interfere with my logging winch).
What they put on was a "street elbow" which looks as though it's designed for use with black iron pipe, rather than hydraulic hoses. Is this sort of plumbing acceptable for use in high pressure hydraulics? This wont get whole lot of constant flow with the grapple, just occasionally opening and closing. I suppose that may change if I added some other type of implement to the FEL that needed constant hydraulic flow, but I can't imagine what I'd be doing with something like that on this little tractor.
On of my reasons for asking is that one of the street elbows started leaking the first time I used it: it's a pretty good drip while the grapple is in motion opening, and a steady stream when the grapple reaches its opening limit. It's going to go back to the dealer who installed it to have this fixed. I'm wondering if I should insist on some other sort of fitting while it's in there.
Pics of fitting below (and grapple for those that are interested). Thanks for any advice/tips.
John Mc
John Mc
