Oil & Fuel Ck 4010HST Propeller Shaft Leak
   / Ck 4010HST Propeller Shaft Leak #1
Samills
Graham, Wa
None
I was doing some clearing the other day and I noticed a hydro trail in the dirt. After looking under the tractor I saw a significant hydraulic leak coming from what I think is the propeller shaft running to the front wheel drive. Anyone else have a similar problem? I only have 20 hrs on the tractor, it's about a month old.
   / Ck 4010HST Propeller Shaft Leak #2
First one I have heard of on the Kioti. That looks like a back to the dealer for warranty repair of the seal for sure.
   / Ck 4010HST Propeller Shaft Leak #3
Back to the dealer, warranty problem. First I've heard of any issues with the new CKs. Probably just the odd issue.
It is at the dealer now...
   / Ck 4010HST Propeller Shaft Leak #5
The dealer said a stick damaged the seal. They were going to submit it for warranty, but were not sure it would be covered. We will see, but I'm a little concerned about the tractor of a little stick can take it down.
   / Ck 4010HST Propeller Shaft Leak #7
How did it get under the shaft cover??
Rancho
You got me, I didn't see a stick when I found the leak.
   / Ck 4010HST Propeller Shaft Leak #9
Little sticks can do some damage if they hit just the right spot.
A little stick got up through and ruined the radiator on my dads Kubota.
   / Ck 4010HST Propeller Shaft Leak #10
Then how do they know if it was a stick that did it? Did they find the culprit?
2012 PETERBILT 388 NATIONAL CRANE TRUCK (A50854)
2012 PETERBILT 388...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A49461)
2014 MultiQuip...
2008 RIB 24 Cat Boat (A50324)
2008 RIB 24 Cat...
Crash Mobile S/A Trailer (A50324)
Crash Mobile S/A...
2006 John Deere 650J LGP Crawler Tractor Dozer (A50322)
2006 John Deere...
PAIR OF 29 FT PIPE RACKS (A50854)
PAIR OF 29 FT PIPE...
