Oil & Fuel Ck 4010HST Propeller Shaft Leak
   / Ck 4010HST Propeller Shaft Leak #1
Samills
Graham, Wa
None
I was doing some clearing the other day and I noticed a hydro trail in the dirt. After looking under the tractor I saw a significant hydraulic leak coming from what I think is the propeller shaft running to the front wheel drive. Anyone else have a similar problem? I only have 20 hrs on the tractor, it's about a month old.
   / Ck 4010HST Propeller Shaft Leak #2
First one I have heard of on the Kioti. That looks like a back to the dealer for warranty repair of the seal for sure.
   / Ck 4010HST Propeller Shaft Leak #3
Back to the dealer, warranty problem. First I've heard of any issues with the new CKs. Probably just the odd issue.
It is at the dealer now...
   / Ck 4010HST Propeller Shaft Leak #5
The dealer said a stick damaged the seal. They were going to submit it for warranty, but were not sure it would be covered. We will see, but I'm a little concerned about the tractor of a little stick can take it down.
   / Ck 4010HST Propeller Shaft Leak #7
How did it get under the shaft cover??
Rancho
You got me, I didn't see a stick when I found the leak.
   / Ck 4010HST Propeller Shaft Leak #9
Little sticks can do some damage if they hit just the right spot.
A little stick got up through and ruined the radiator on my dads Kubota.
   / Ck 4010HST Propeller Shaft Leak #10
Then how do they know if it was a stick that did it? Did they find the culprit?
Kioti DK45 Tractor (A50860)
Kioti DK45 Tractor...
2014 STEPHENS 200BBL TANKER TRAILER (A50854)
2014 STEPHENS...
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
71062 (A49346)
71062 (A49346)
Gravelly Pro-Turn 148 48in Zero Turn Mower (A48082)
Gravelly Pro-Turn...
2014 STONE RIDGE 38FL 5TH WHEEL CAMPER (A50854)
2014 STONE RIDGE...
