gc1720 headlight replacement
   / gc1720 headlight replacement #11
my manual says 13 watts a bulb. We have 4 headlights on the gc series all. You can also compre it to a 194.
Ray what do the lights look like on your tractor?
I have a 23 watt metal base bulb on my GC2310, like Irving.
But, there are only two of them. No, they are not particularly bright.
The 921 is a few more watts. That shouldn't hurt. Only cost you a few bucks to try them. Watch for excessive heat build up.
Yea i bought a different couple ones to see what will fit. Ill post back up and keep you guys updated.
   / gc1720 headlight replacement #14
the picture of the headlights
Four of these make up the extent of my stock forward lighting. The LED mounted on my ROPS far, far, outshines these little candle sticks. Hope your LED replacements work out, I'll be interested in getting some too.
Thanks,
Jeff
Thanks,
Jeff
O yea the rops led bars are superior. I really haven't used my tractor late at night yet so i figured the 30 bucks for all 4 front lights wont be that bad now. The stock lights are Really low end lighting for something so expensive.
   / gc1720 headlight replacement #16
If you were building these, what would you choose to make cheaper, to give it better headlights?
Because, that's how it works.
Not sure what you mean. But how I look at things is this, Its 2015 not the year 2000. The technology for 2015 is led, hid not incondesecent bulbs. Especially the bulbs that Massey is usung are as bright as my dome lights in my car. I might be new to tractors but im not new too buying products.
I can compare my 2015 gc1720 headlights to my 1999 John Deere d130"riding lawn mower. I would just expect the newer age product to be superior, not the same.
Im not knocking Massey but i can sure say what is good and what I think is bad. This isnt service related, its a design and money thing. ,
   / gc1720 headlight replacement #18
You can knock MF all you want. I have my complaints with them.
You seem to be suggesting, they either didn't care about the lighting, of can't figure out how to design it properly?
It is, "a money thing". You don't just build a tractor, with the latest bells and whistles, and whatever it ends up costing, you put it out there, and see if it sells.
You start with a price point, and work backwards. That price is determined by market research.
So, when I ask what would you make cheaper, to put hid lights on this tractor? That's because the cost has to come out of some other part of the budget.
There are lots of things they could upgrade on these for a little more money. The problem is, you already think it's an expensive machine.
So, if they added another lets say, $1500 to the price, to put on better cylinders, better hoses, a stronger steering controller, a better seat, and better lighting. But, loose a ton of sales, and don't make a profit, because the competition beats them on price. Why build it then?
If, you buy a tractor this size, in commercial grade, it can cost you nearly twice what you paid. But, other than being built to withstand the abuse, a piece of rental equipment gets, it won't do anything yours doesn't. So, I don't think these are expensive.
My point is further illustrated, by the fact that, the original GC had neither a tach, or a temperature gauge. But, the dash had been designed to accommodate them? These are not essential items, so when the budget got tight, they undoubtedly cut them out of the final design. Later, when they knew they could get enough of the market, and the price of the competing equipment allowed for them, they were added.
well im going threw this machine little by little. Im happy with alot, but would like some things better, but its a blast to work with. I also know others company machines even had cheaper stuff. As fpr now I cant talk for the cylinders, engine, hydro because that would def have to be a long term review. I can speak for wiring, lightings amd eletrical stuff because i know a lot about this area.
Ill post up my led headlights when i get em. Check out my led brake lights tho. Pretty cool man!
Well got my led light bulns tody and they fit perfect. Wasnt dark out but took some pictures. Ill take some pixtures of them at night also.
4 bulbs 30 bucks. If they are 2-3 times brighter then stock im happy. Will do some night testing and let you guys know.
2016 Dodge Ram Promaster 1500 (A53317)
2016 Dodge Ram...
2015 Ford Taurus SE Sedan (A55853)
2015 Ford Taurus...
UNUSED FUTURE MINI EXCAVATOR ATTACHMENT (A57193)
UNUSED FUTURE MINI...
2020 JOHN DEERE 317G SKID STEER (A52707)
2020 JOHN DEERE...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A55315)
2023 Kubota...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A57024)
2023 Unverferth...
