Constipated weed trimmer
   / Constipated weed trimmer #1
Paddy
Bloomington, IN
Kubota, G5200, KAMA 454
I have a Stihl FS 55R weed trimmer. Last fall I could not get the dang thing started. A few years back I had replaced the carb and she ran just fine so I thought it was the same issue. No such luck.
I had Googled how to adjust the carb when I saw a reference to "most often it's not your carb but a clogged Spark arester in the exhaust system. Sure enough, cleaned it out, put old carb back on. She started first try.
So if you have 2 cycle engines that have lost power or just wont start, see if exhaust is constipated!
Easy Repair on STIHL FS38 Grass Trimmer - Clogged Spark Arrester - YouTube
   / Constipated weed trimmer #2
The same goes for your 4 stroke engines too. Shove a potato into your tailpipe on the pickup/car and see how long it runs!
   / Constipated weed trimmer #3
I had the same thing happen on my old Poulan weedeater. It would crank up ok but never gain the RPM needed for power. I tried everything to clean the carb but nothing helped. Took it to the shop and it was the muffler stopped up with carbon. The mechanic asked if I had been running it at slow speed and I said yes, I only run it fast enough to do the job so it isn't slinging rocks and such around so much. He said that type of running will cause the exhaust to carbon up fast. I do still run my Stihl slower than wide open throttle at times but still open it up when I need to for heavy grass.
   / Constipated weed trimmer #4
I've had to do this with my Stihl blower at least 3 times.
It goes from nothing or terrible running to like brand new as simple as that!
I wonder how many people have junked theirs because of the issue.
Travis
   / Constipated weed trimmer #5
I've done that to people I don't like in the past. Use a stick to shove it up a ways so it cannot be seem. Amazing how well it works....or don't work.:thumbsup:
Everything,
Yes I too wonder how many I have tossed over the years over something simple. I have a leaf blower that starts hard or hardly. And if it does, it needs the chock half on.
   / Constipated weed trimmer #7
Everything,
I'm pretty sure I tossed a cheapo cub cadet weed eater with the same symptoms.
The rest of it was past wore out, so I didn't feel bad after learning the trick. :laughing:
Travis
   / Constipated weed trimmer #8
That little screen is to satisfy the USDA for spark arresting.... I toss it when I open the mufflers up.
   / Constipated weed trimmer #9
The spark arrestors cause a multitude of performance issues.
My trimmers are all used in the Spring before everything turns tinder dry...
The one in the old Echo has a big hole in the middle of the screen from years of use/exposure.
   / Constipated weed trimmer #10
It can also happen when dirt-dauber hornets build nests in the muffler. This is particularly common with little 2-cycle engines with a short stub of "tailpipe" on the muffler, and where they are stored in a shed. I have resorted to whittling little plug sticks for the tailpipes and tying them on with cord so they don't get lost while the engine is in use.
2011 BMW X5 SUV (A50324)
2011 BMW X5 SUV...
David Bradley Manure Spreader (A50515)
David Bradley...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2007 GMC W4500 Landscape Dump Truck (A50323)
2007 GMC W4500...
2013 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2013 Chevrolet...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
