murphy1244
Super Star Member
- Joined
- Nov 25, 2011
- Messages
- 16,336
- Location
- Ohio
- Tractor
- Kubota 1120 RTV Kioti DK-40, MF-135, Ventrac 4500Y
I think he's referring to the mechanic friend mentioned in the first post.
I was, Thank you.:thumbsup:
If you google and read the instructions for "Time Sert" repair tool kit it says that the tool set covers Ford 4-6-8 and 10 cylinder engines from 1993 thru 2004.
Now that is a flat learning curve!
In 2005 Ford went to a two piece spark plug. While they stay in they are prone to carbon up and break off when trying to remove, BUT they don't blow out!
If you have ever heard one of those engines being driven with the plug blown out it has a LOUD whistling sound.
I trust this will not happen with my 2016 F150 with a 5.0 L?
If it's got a 5.4 V8 in it, RUN!:thumbsup:
Correct. This is the 5.4L engine that is affected. They built three different generations of that engine, and gen 1 is the one that spits out plugs. Gen 2 went to a two piece plug that won't spit out, but has a tendency to snap off when being removed sometimes due to excessive carbon build up at the tip. The Gen 3 version of the 5.4L doesn't suffer from either of these issues.
