replacing a bad TA in a IH 350
   / replacing a bad TA in a IH 350 #1
klink
Ohio
Ford 660,JD 4110 Hydro - JD 670 gear - 48 Farmall Cub - 51 Farmall H - John Deere 50 - JD X540 JD X580 AC 917 WH 81 Cub Cadet 1541 & 70
Hi
How hard and or expensive is it to replace a bad TA in a IH 350. I've never had any experience in replacing or repairing a TA on old Farmalls. Any and all info would be appreciated on the subject. I did not do much searching in forums on the subject.
Thanks
klink
   / replacing a bad TA in a IH 350 #2
It won't be cheap and on some IH models, TA's aren't even available any longer.
Better check that out first...
SR
   / replacing a bad TA in a IH 350 #3
Hi
Thanks
klink
There are several components to a mechanical TA that can be replaced a la carte. HyCapacity has everything you will need, and many CaseIH dealers use their stuff instead of OEM.
What are your symptoms?
Its a tractor that I'm interested in buying and have not driven yet IH 300
   / replacing a bad TA in a IH 350 #5
Drive it and post back exactly how it drives. It WILL freewheel in TA mode; it's the nature of the mechanical TA beast.
You will likely find it drives OK in Direct and not at all in TA.
   / replacing a bad TA in a IH 350 #6
What is a TA?
   / replacing a bad TA in a IH 350 #8
International dealers made a LOT of money in the 50s - 80s replacing TAs . Pulling them back under load , down hill or at the endrows kills them . The easiest fix is to delete it . You could get factory delete TA in most models in those years .If you want to repair it look at how you are going to use it . I myself would use them old Deeres .
Thanks for all the replies. Maybe I don't want a TA after all. I have never driven a 300 or 350 before. Here is the reason I wanted a Farmall w/TA. I currently own a Farmall H and I go on tractor club sponsored tractor rides and my biggest problem is starting out in 5th gear on inclines. I thought it would be easier to start out in 5th gear low range and then push lever into high range after moving, thus avoiding a stall out. On flat roads I have less problems. I have always thought the H & M-s biggest drawback is the 5th gear ratio. There is to much difference between 4th and 5th gear ratio-speed. just my personal opinion. I have talked to many Farmall H owners and they love the 5th gear speed.
   / replacing a bad TA in a IH 350 #10
I think you are wanting a tractor with TA for a good reason. And you are being spooked on the idea for less than accurate ones.
TA's can fail, can be made to fail, and also can live long and productive lives when treated right.
ASSET DESCRIPTIONS & CONDITION (A52141)
ASSET DESCRIPTIONS...
400 bu Gravity Wagon (A50514)
400 bu Gravity...
UNUSED JCT SKID STEER QUICK ATTACH TRENCHER (A51244)
UNUSED JCT SKID...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
Brent 776 Grain Cart (A50514)
Brent 776 Grain...
