I finally did it... I bought a small tractor... then discovered I NEED MORE! ;)
   / I finally did it... I bought a small tractor... then discovered I NEED MORE! ;)
Is the iseki very noisy with the straight pipes?
Yes, its VERY noisy! ;) I'm working on making a manifold or using the existing twin manifolds and welding a small box chamber with a mount for a muffler on top.
:welcome: Is that a Harbor Freight trailer the Yanmar is sitting on?
hey Stuck, it is! and the deck isn't even bolted on... just a 1" piece of plywood strapped to the frame... hehe... and that was about the heaviest load its ever taken and it did great! probably 2500-2700lbs? with the calcium filled tires...
Thanks everybody for the advice and welcomes! :D I'm gonna go outside as soon as the rain lets up some and try some of these maneuvers for unsticking clutch! ;)
   / I finally did it... I bought a small tractor... then discovered I NEED MORE! ;) #14
Welcome to the forum, It sounds like you've got enough to keep you busy over there. :)
well since my previous posts I have bought and refurbished a pretty large Model LAS 48" bucket self leveler Kwik-Way loader that ends up being a lil too big for my Bolens, and I have decided to sell it...
But!!! I have already purchased another kwik way loader that should do the trick, this one attached to a great running Sears Suburban GT16! Sears Model 100 Loader. :D
Tis a shame that they will have to be separated! muahaha!
00G0G_6X8AodjgmBH_1200x900.jpg00b0b_1P8oKp8LBiU_1200x900.jpg00808_3ntsPPDCjio_1200x900.jpgs-l1600-10.jpg
   / I finally did it... I bought a small tractor... then discovered I NEED MORE! ;) #16
I've got one of those. It took me a while to get it together.
   / I finally did it... I bought a small tractor... then discovered I NEED MORE! ;) #17
How did you free the clutch?? Inquiring mind went to know....
   / I finally did it... I bought a small tractor... then discovered I NEED MORE! ;) #18
I can vouch for the Kwik-Way loaders being well built. In the far distant past I had two of the self leveling loaders, here is one, that I planned to use on the TORO:
Then I got this 2 inch wider Kwick-Way at an auction and used it instead:
Looking forward to more pictures of your project. :thumbsup:
2024 Bobcat T770 (A53317)
2024 Bobcat T770...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2020 Caterpillar 259D3 Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
