I finally did it... I bought a small tractor... then discovered I NEED MORE! ;)
   / I finally did it... I bought a small tractor... then discovered I NEED MORE! ;)
Is the iseki very noisy with the straight pipes?
Yes, its VERY noisy! ;) I'm working on making a manifold or using the existing twin manifolds and welding a small box chamber with a mount for a muffler on top.
:welcome: Is that a Harbor Freight trailer the Yanmar is sitting on?
hey Stuck, it is! and the deck isn't even bolted on... just a 1" piece of plywood strapped to the frame... hehe... and that was about the heaviest load its ever taken and it did great! probably 2500-2700lbs? with the calcium filled tires...
Thanks everybody for the advice and welcomes! :D I'm gonna go outside as soon as the rain lets up some and try some of these maneuvers for unsticking clutch! ;)
   / I finally did it... I bought a small tractor... then discovered I NEED MORE! ;) #14
Welcome to the forum, It sounds like you've got enough to keep you busy over there. :)
well since my previous posts I have bought and refurbished a pretty large Model LAS 48" bucket self leveler Kwik-Way loader that ends up being a lil too big for my Bolens, and I have decided to sell it...
But!!! I have already purchased another kwik way loader that should do the trick, this one attached to a great running Sears Suburban GT16! Sears Model 100 Loader. :D
Tis a shame that they will have to be separated! muahaha!
00G0G_6X8AodjgmBH_1200x900.jpg00b0b_1P8oKp8LBiU_1200x900.jpg00808_3ntsPPDCjio_1200x900.jpgs-l1600-10.jpg
   / I finally did it... I bought a small tractor... then discovered I NEED MORE! ;) #16
I've got one of those. It took me a while to get it together.
   / I finally did it... I bought a small tractor... then discovered I NEED MORE! ;) #17
How did you free the clutch?? Inquiring mind went to know....
   / I finally did it... I bought a small tractor... then discovered I NEED MORE! ;) #18
I can vouch for the Kwik-Way loaders being well built. In the far distant past I had two of the self leveling loaders, here is one, that I planned to use on the TORO:
Then I got this 2 inch wider Kwick-Way at an auction and used it instead:
Looking forward to more pictures of your project. :thumbsup:
2020 Toro Pro Sweep Vacuum (A55758)
2020 Toro Pro...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56435)
Kuhns AE10 Small...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2017 FORD F550 CAB & CHASSIS (INOPERABLE) (A58214)
2017 FORD F550 CAB...
Carry-On 5'x8' Trailer (A53316)
Carry-On 5'x8'...
2020 MACK P164T (A58214)
2020 MACK P164T...
