Kubota BX2200 with LA112 Front Loader
   / Kubota BX2200 with LA112 Front Loader #41
So I fixed my gauge problems today...very easy...just jiggled the fuse holder and they functioned normally. All I did was remove, clean and reinstall the 15 amp acc fuse.
Where is the fuse holder?
   / Kubota BX2200 with LA112 Front Loader #44
Congrats on the new/used Kubota BX2200. I have one myself that I love. It currently has 654 hours and I have changed out the hydraulic lines, plus the regular maintenance.
I was wondering what mower blades you guys were using. A few years ago I switched to the Gator blades, which seemed alot heavier that the OEM blades. I didn't run them last year and just put them back on tonight. I do see a difference in the cut. I have the regular 54" deck. I notice that the middle blade was not cutting level with the other two on two or three different passes. I used the OEM bolt, hex washer, and two spring washers. It seems that with the middle blades there is a little less thread to grab.
Has anyone had this problem and if so, what can I do to fix the issue. Does Kubota make thinner spring washers?
Thanks in advance
I am also having an issue with the light switches and blowing a fuse. It has been this way since I bought it (used) five years ago, but I'll deal with that another time when the grass is snow covered!
Jeff
2025 Safety Basket Forklift Attachment (A51691)
2025 Safety Basket...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
2019 Chevrolet Tahoe SUV (A52377)
2019 Chevrolet...
14ft S/A Utility Tilt Trailer (A51694)
14ft S/A Utility...
