Kubota BX2200 with LA112 Front Loader
   / Kubota BX2200 with LA112 Front Loader #41
So I fixed my gauge problems today...very easy...just jiggled the fuse holder and they functioned normally. All I did was remove, clean and reinstall the 15 amp acc fuse.
Where is the fuse holder?
   / Kubota BX2200 with LA112 Front Loader #44
Congrats on the new/used Kubota BX2200. I have one myself that I love. It currently has 654 hours and I have changed out the hydraulic lines, plus the regular maintenance.
I was wondering what mower blades you guys were using. A few years ago I switched to the Gator blades, which seemed alot heavier that the OEM blades. I didn't run them last year and just put them back on tonight. I do see a difference in the cut. I have the regular 54" deck. I notice that the middle blade was not cutting level with the other two on two or three different passes. I used the OEM bolt, hex washer, and two spring washers. It seems that with the middle blades there is a little less thread to grab.
Has anyone had this problem and if so, what can I do to fix the issue. Does Kubota make thinner spring washers?
Thanks in advance
I am also having an issue with the light switches and blowing a fuse. It has been this way since I bought it (used) five years ago, but I'll deal with that another time when the grass is snow covered!
Jeff
2004 GMC Envoy SUV (A51694)
2004 GMC Envoy SUV...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A52377)
2012 Chevrolet...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
2015 DODGE RAM...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
2013 Ford Edge SEL SUV (A51694)
2013 Ford Edge SEL...
