Gooseneck with a single dually axle?
   / Gooseneck with a single dually axle? #1
LD1
Epic Contributor
Central Ohio
Kubota MX5100
Benn looking for a smaller trailer, browsing Craigslist, and seen a 26' gn trailer that has a single dually axle.
Anyone ever see one like that? I never have. Looks like a PITA to get load balanced right.
It almost looks like a typical 24k trailer with the front axle removed, but the gn hitch don't look beefy enough. Looks like a 14-16k gn hitch.
Not really interested in the trailer, just curious. Funny the guy says " will haul 24k no problem".......
Not with a single axle it won't.
   / Gooseneck with a single dually axle? #3
Hard to tell much from his pictures:
I think the second pic is most telling. The whole hitch part looks smaller. And that they are clear out at the edges of the trailer and not where the center beams would "normally" be.
But in either case....its a single dually axle. Never seen one....new, used, or homemade like that until now.
And being a 26'9" trailer....load balancing looks to be a PITA.
And the comment the guy has that says "it will haul 20-24k and more".......not on a single 12k axle it wont.
   / Gooseneck with a single dually axle? #5
You know you want it.
No. Actually looking for something smaller. Well....actually looking for two trailers.
1. 6' wide landscape trailer. Could be anythign from 10' long and single axle to 18' two axle. Something light to tow my 61" ZTR on, and to take if I buy a blade or disc or other implement that is a good distance away. Its kinda silly towing a 24K GN 2 hours away to pick up a 6' disc:mur:
2: Would like to find a 22-24' equip trailer, 10k-14k. Could be a GN or BP. But 4 tires and tandem axles. Would be more economical towing tractors on it rather than the 24K GN. But cannot part with the 24k trailer either though, cause there are times when I need the capacity.
   / Gooseneck with a single dually axle? #7
That looks like an old trailer but i agree, the tongue just doesn't look heavy enough!
I swear ppl post stuff on cl just to see what kind of interest they get or what they can get away with. That or they have absolutely no idea what in the world they are talking about and don't realize it. I especially like when they advertise a 25.9 gvw trailer and state its "under cdl" or that they have an x ton capacity dump truck but they have hauled 1.5X tons. Yeah go ahead and warn me to walk away before I even make contact!
I'm in the same situation as you though. I have a 14.5k GN but I would like to get a 24k-28k trailer for some bigger things I would like to move around.
Tongue looks pleanty heavy considering its a 12k trailer (single axle). But certainly no where near a 24k rating IMO. Which makes me think the trailer was made like that vs just having the front axle removed?
   / Gooseneck with a single dually axle? #9
well not heavy enough for 24k is what I meant. If it was factory 12k trailer ,it would work just fine I would think.
   / Gooseneck with a single dually axle? #10
How do we know it is a 12k axle? Hard to tell from the pics but those tires look big like 22.5's. Semi trailer axles can be good for 20k per axle. My 53' spread has two spread axles and I can scale 40k on the trailer axles.
Load balancing really isn't much different regardless of the number of axles. If you place a load on that trailer and weigh the weight on the tires and tongue and then replaced the single axle with a tandem setup centered where the single axle was your weight on the tires and tongue will be very close to the same.
   / Gooseneck with a single dually axle? #11
First it does look different and not sure with the picture but there looks like there is factory tag on the hitch leg so that ought to be helpful to verify. Second the axle looks to me really far back, if so then it is putting good bit of load on the tow truck. Third I have seen this design but only in picture and then only for sale..
If I had any real interest would ask for info off the label and verify it's capacity and such. The company MAY still be in business.
It dont look like a big axle to me. Looks like 16" tires and a 12k axle jsut like the pair under my GN.
And the axle looks like its positioned where my rear axle is....not centered between where a dual tandem would be. I could be wrong.....but thats the way it loos to me
Actually if you loo at the pic that Xfaxman kindly posted, it looks like the single axle is centered about right where the dove starts.
Thats even further rearward than my 24k dual tandem. And my trailer is 1'9" shorter if his measurement is correct
   / Gooseneck with a single dually axle? #14
To me, it looks like someone took an old (50's? 60's?) 5th wheel semi flatbed and added a goose. The only stickers I see are the reflective ones like you can find everywhere from HF to TSC.
He says "tires are 8.25x20". About all I can find online that size are bias ply, rated 3500-5000 ea. (not including the derate for use as duals). So 14-20k on the axle, plus whatever you think that goose can hold. Aren't most 20" rims split-ring? I can't see the axles well enough to tell if they are cast hubs or steel rims.
So I guess my first question would be, just how OLD are those tires? How bare are they, and how many plies are showing through?
   / Gooseneck with a single dually axle? #15
Interestingly, it looks like it has a jack on the coupler to adjust the ball height (see the handle on the top of the gooseneck coupler tube).
Aaron Z
   / Gooseneck with a single dually axle? #16
Looks like a semi trailer axle to me. There are some local companies around here that have similar trailers to skirt around the proper drivers license. They will pull a large gooseneck trailer with a single semi axle running electric brakes. In Alberta you only need a class 1 license if the trailer has air brakes. So they basically run around with five tons with hydraulic brakes pulling these weird looking trailers that run electric brakes.
   / Gooseneck with a single dually axle? #17
Aaron Z
Yep, I have seen that type of jack, but never built in to the coupler by any trailer manufacturer. There are square tube couplers available, they aren't all round.
The gooseneck frame is very light duty, another clue that this was a homemade conversion.
If that was indeed a jack, with the bottom of the leg chopped and converted to accept a ball, I don't think I'd be caught dead towing that. Jacks are typically alot thinner material than would be on a gn tongue.
I missed the part about 8.5x20 wheels. Maybe the axle is up to snuff, and maybe there deck is too? But the hitch.... certainly isn't as the guy claims "....24k and more"
   / Gooseneck with a single dually axle? #19
The jack for neck adjustment is something I've seen before on factory built trailers. They're built plenty heavy, this one...who knows.
   / Gooseneck with a single dually axle? #20
It says 8.25-20 tires. Those are rated 7800kg at 7 bar pressure. Or about 17200 pounds. Counting a 5k for the trailers empty weight, and 3k hitch capacity, it still comes short for a 24k load, and because of the expected age of 8.25-20 tires i wouldnt try either...
Between 2005 and 2008 i designed plenty of them. Only problem with load balancing was with an enclosed box trailer with a hydraulic loading tailgate. Dead weight of the tailgate meant that the axle has to be put to the back to get at least some 5th wheel load when driving empty, and because of the nature of the box (opening at the rear) one would start loading it above the 5th wheel, which would overload the tow vehicle with a half load.
set of 4 tractor trailer tires Roadforce (A56438)
set of 4 tractor...
2001 JOHN DEERE 310SG BACKHOE (A60429)
2001 JOHN DEERE...
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
2012 Chevrolet Traverse LT SUV (A59231)
2012 Chevrolet...
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
