first major bummer with my tractor
   / first major bummer with my tractor
ok there is no adjustment knob but there is the backpin that sets the height on my tractor. also the midmower manual - i will check in a while. this is very frustrating. drove a tractor for over 50 years - i am stuck. Thanks.
well looked through the manual and i do not see how the piece that is too high to hook to the mower moves that much - so.... will check it out in a while - will try one more time in another place - the driveway. i did it on the grass - so we'll see.
   / first major bummer with my tractor #13
So you can't lower the mm lift linkage? If so try raising the deck up to attach ??
Pictures ????
Sent from my iPad using TractorByNet
i saw that many times and wrote notes on it -
question clutch in to engage mower and clutch in to disengage mower?
   / first major bummer with my tractor #16
Sorry, thought you would have the same set up, I guess the Max 25, 24 have some differences.
no i dee the dial and i adjusted it - one way nothing works the other it works.
tried it again on driveway = got over the mowever now the mower slides in 4wd so i cannot get back over it even with wood blocks
Ok thanks toyou all - turns out i had to stand on the actual 2" 2.5" 3" etc metal half moon pieces for height adjustment to drive the rest of the unit down - it worked it was so tight you had to do it. also i just found a front right hydraulic leak - ****. That had better be covered under warranty.
:) Thanks again everyone....I had another tractor guy who rebuild s them check and he was questioning this too.... we both could not figure why it did not drop down all the way.
Hey guys - this right front hydraulic leak - that should be covered under warranty - correct - the delalers around here are quite shabby - and they would rather charge you the customer then take care of a warranty issue and get their $ from mahindra. the 2 dealers that i have and am dealing with.
That aspect to me has been the negative of my mahindra experience.
2019 Dodge Challenger Passenger Car (A51694)
2019 Dodge...
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
King Kutter XB 3pt 4' Mower (A50120)
King Kutter XB 3pt...
2023 Diamond Cargo Trailer (A50324)
2023 Diamond Cargo...
2011 FORD F-350 SUPER DUTY (A52472)
2011 FORD F-350...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
