first major bummer with my tractor
   / first major bummer with my tractor
ok there is no adjustment knob but there is the backpin that sets the height on my tractor. also the midmower manual - i will check in a while. this is very frustrating. drove a tractor for over 50 years - i am stuck. Thanks.
well looked through the manual and i do not see how the piece that is too high to hook to the mower moves that much - so.... will check it out in a while - will try one more time in another place - the driveway. i did it on the grass - so we'll see.
   / first major bummer with my tractor #13
So you can't lower the mm lift linkage? If so try raising the deck up to attach ??
Pictures ????
Sent from my iPad using TractorByNet
i saw that many times and wrote notes on it -
question clutch in to engage mower and clutch in to disengage mower?
   / first major bummer with my tractor #16
Sorry, thought you would have the same set up, I guess the Max 25, 24 have some differences.
no i dee the dial and i adjusted it - one way nothing works the other it works.
tried it again on driveway = got over the mowever now the mower slides in 4wd so i cannot get back over it even with wood blocks
Ok thanks toyou all - turns out i had to stand on the actual 2" 2.5" 3" etc metal half moon pieces for height adjustment to drive the rest of the unit down - it worked it was so tight you had to do it. also i just found a front right hydraulic leak - ****. That had better be covered under warranty.
:) Thanks again everyone....I had another tractor guy who rebuild s them check and he was questioning this too.... we both could not figure why it did not drop down all the way.
Hey guys - this right front hydraulic leak - that should be covered under warranty - correct - the delalers around here are quite shabby - and they would rather charge you the customer then take care of a warranty issue and get their $ from mahindra. the 2 dealers that i have and am dealing with.
That aspect to me has been the negative of my mahindra experience.
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
2015 Club Car Golf Cart (A50324)
2015 Club Car Golf...
2005 GMC Sierra Pickup Truck, VIN # 2GTEK13T851399344 (A51572)
2005 GMC Sierra...
2007 Toyota Corolla Sedan (A50324)
2007 Toyota...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
