first major bummer with my tractor
   / first major bummer with my tractor
ok there is no adjustment knob but there is the backpin that sets the height on my tractor. also the midmower manual - i will check in a while. this is very frustrating. drove a tractor for over 50 years - i am stuck. Thanks.
well looked through the manual and i do not see how the piece that is too high to hook to the mower moves that much - so.... will check it out in a while - will try one more time in another place - the driveway. i did it on the grass - so we'll see.
   / first major bummer with my tractor #13
So you can't lower the mm lift linkage? If so try raising the deck up to attach ??
Pictures ????
Sent from my iPad using TractorByNet
i saw that many times and wrote notes on it -
question clutch in to engage mower and clutch in to disengage mower?
   / first major bummer with my tractor #16
Sorry, thought you would have the same set up, I guess the Max 25, 24 have some differences.
no i dee the dial and i adjusted it - one way nothing works the other it works.
tried it again on driveway = got over the mowever now the mower slides in 4wd so i cannot get back over it even with wood blocks
Ok thanks toyou all - turns out i had to stand on the actual 2" 2.5" 3" etc metal half moon pieces for height adjustment to drive the rest of the unit down - it worked it was so tight you had to do it. also i just found a front right hydraulic leak - ****. That had better be covered under warranty.
:) Thanks again everyone....I had another tractor guy who rebuild s them check and he was questioning this too.... we both could not figure why it did not drop down all the way.
Hey guys - this right front hydraulic leak - that should be covered under warranty - correct - the delalers around here are quite shabby - and they would rather charge you the customer then take care of a warranty issue and get their $ from mahindra. the 2 dealers that i have and am dealing with.
That aspect to me has been the negative of my mahindra experience.
J and L Cargo Express Shadowmaster Enclosed Trailer (A52748)
J and L Cargo...
Chevrolet C8500 Flat Bed with a Moffet Kit (A52748)
Chevrolet C8500...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
