Kubota B2601 Hydraulic PHD vs PTO driven
   / Kubota B2601 Hydraulic PHD vs PTO driven
As a rule, do you generally operate at the full 540 rpms (PTO) or is slower better?
   / Kubota B2601 Hydraulic PHD vs PTO driven #12
I run everything pto at the full 540 RPMs. It is probably less critical for PHD or seeder than a brush cutter where you create strain running at a lower rpm. Kinda like driving a 4 speed car in 4th gear at 30 MPH.
   / Kubota B2601 Hydraulic PHD vs PTO driven #13
PHDs are the exception to the rule... I barely run mine above an idle. If you run it fast, you'll only do that once before you realize that's a bad idea.
   / Kubota B2601 Hydraulic PHD vs PTO driven #14
I guess that really depends on your ground conditions. Where I'm at you run full pto rpm until you break through the hard clay layer (12 to 16") Working for every inch until you break through to something that has a moisture content then let it corkscrew 5-6 inches and pull out of it. Even then I'm running close to 540.
   / Kubota B2601 Hydraulic PHD vs PTO driven #15
Wow... I ran mine at part throttle once & that was plenty scary. I had clay issues in til I got better teeth for my auger. Id go a foot, hit clay & that was it. A few hundred lbs on the auger or water in the hole overnight didnt help at all. It had fat frost & rock carbide teeth. Put in thinner sharper ones & that helped. That was on a beefy nice name brand auger started with a P I think. My cheaper 12" from the local ranch store has even less issues. Thinner teeth that will wear out a LOT faster I'm sure, but they dot even flinch when they hit the clay layer.
   / Kubota B2601 Hydraulic PHD vs PTO driven #16
I've corkscrewed mine a couple of times. Takes all the fun out of it. :eek: Just have a fairly good sized cheap pipe wrench and four foot piece of pipe (conduit will work fine and is cheap) that will slip over the handle of the pipe wrench. Then just back it out, only takes a few minutes...unless you are like me and the dang thing sinks all the way to china. Slow and easy is best. One thing that does help when removing it is to leave the tractor running with the lift on "up" and pto off. Then when you do get it loosened somewhat, the tractor will simply pick it on up out of the hole. :thumbsup:
2022 JOHN DEERE 6120M LOT NUMBER 192 (A53084)
2022 JOHN DEERE...
378812 (A51573)
378812 (A51573)
Quick Attach Skid Steer Plate (A51573)
Quick Attach Skid...
1993 Ford F700 Stakebody Flatbed Truck (A51692)
1993 Ford F700...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
