New Holland TC21 needs a little repair
   / New Holland TC21 needs a little repair #11
Ken: Good work. Thanks for sharing it.
Yes, the tires are the correct sizes. Now that the wear and tear (abuse) from the previous owner has been resolved I will adopt the practice of using 4wd when absolutely needed. And another note: After this repair I do have Hi-Med-Lo ranges. As bought it with only Hi-Med. The older guy that delivered the tractor told me I would not use the Lo range anyway. He was right. It's really slow but I'm glad it works and better to resell if I ever want to.
I too was interested to learn about the different gear ratios for front and rear drives. I thought about that while I had the machine jacked up but didn't take the time to "count" the rotations. I just retired from a career as a mechanical designer so would have thought the ratios would have been 1:1....but then I didn't design tractors! Thanks for that information.
Ken
   / New Holland TC21 needs a little repair #13
Hi, still learning how to negotiate the forum, I have a stuck throttle stuck at 2400 rpm. Any suggestions on how to adjust or lubricate the throttle / cable to fix the "stuck" throttle would be greatly appreciated. Thanks for any comments.....Ed Striedl
Sorry. I don't have anything to suggest and tractor is not handy to go look at. My experience with oiling a sheathed cable is that it will eventually get gummed up with dust and becomes routine maintainance after that. Maybe spray cable/linkages with a lubricant that dries up and leaves a film?
-Ken
   / New Holland TC21 needs a little repair #15
Hi. I was able to gleen information about the location of the cable to the extent that the problem was at the engine side and with using a cleaner / lubricant I was able to free the linkage that the throttle is now moving and allowing the RPM to work! I thank you for the information on the forum to give me enough info to fix my problem!!!!! THANKS for the support!...ed
   / New Holland TC21 needs a little repair #16
Hopefully someone can help me out here. TC-21 tractor same as in pic but much more rust. I can't shift 2 or Reverse but 1st and 3rd shift fine. I figured I would pop the case off and inspect the shifter rods but I cannot for the life of me get this cover off. I don't want to break it by prying. All of the bolts are out. What am I missing or is this even possible?
   / New Holland TC21 needs a little repair #17
I got the case off finally with a little tender persuasion. Have to see if anything is broke or not.
UNUSED RAYTREE RMBC72-72" BLOCK CRUSHER (A51248)
UNUSED RAYTREE...
2016 Nissan Sentra Sedan (A51694)
2016 Nissan Sentra...
2016 Ford Escape SUV (A51694)
2016 Ford Escape...
2021 PETERBILT 567 DAY CAB (A53426)
2021 PETERBILT 567...
WOODS DS8.50 LOT NUMBER 231 (A53084)
WOODS DS8.50 LOT...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
