Faucet replacement
   / Faucet replacement #1
rekees4300
Elite Member
Indiana
JD4300
I have a hose faucet that drips and needs to be replaced. It's attached to a drop ear elbow which is soldered to 3/4 inch copper pipe. Threads are sealed with what appears to be plumbers putty (aka pipe dope). Have tried to unscrew it with 2 biggest wrenches I have and it wont budge. Afraid of breaking the copper pipe. Any suggestions?
View attachment 471514View attachment 471508
   / Faucet replacement #2
Is there anyway you can support the elbow and then remove the hose bib?
Sometimes a little heat can work wonders too.
   / Faucet replacement #4
Turn off water to faucet and get cheater bar for pipe wrench.
Try to support elbow
   / Faucet replacement #5
Turn off water, drain line, unsolder elbow from copper pipe, clamp elbow in vise and remove / replace faucet, resolder elbow to copper pipe and turn water back on.
   / Faucet replacement #6
This is what will be required after using a cheater bar or bigger wrenches. Try heat first and then do it the easy way!
   / Faucet replacement #7
So far this year I've had to replace the rubber gasket inside four outside faucets. I don't understand what's going on with them, or why all of a sudden so many of them are falling apart. Fortunately all of my faucets are the kind that I can unscrew the tops of them and get to the gasket without having to take the entire spicket off of the wall.
Hope you can get it off, but sometimes no matter what you do, you just have to cut the pipe and sweat on a new fitting.
Is the faucet the kind that can be repaired?
How to Fix a Leaky Outdoor Faucet - YouTube
No, there is no way to repair the faucet. Handle isn't removable. Thanks for all the suggestions. I'll try pipe wrench with cheater bar first then if that doesn't work will add some heat. Should the heat be applied to faucet or elbow? If applied to faucet wouldn't that cause threads to expand making them even tighter? If applied to elbow wouldn't that cause solder to melt? :confused3:
   / Faucet replacement #9
I think it's just really tight in order to have the tap vertical should get it with patience and a cheater bar. Could replace it with a ball valve tap not more drips.
   / Faucet replacement #10
apply heat (not a lot) B-4 trying to break it free.. I don't worry about replacing rubber seals /gaskets in outside spigots.. I replaced with 1/4 turn ball valves
2011 NISSAN FRONTIER EXTENDED CAB TRUCK (A51247)
2011 NISSAN...
2013 Chevy Silverado 2500 HD (A55218)
2013 Chevy...
2025 Swict 78in Bucket Skid Steer Attachment (A53421)
2025 Swict 78in...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
2017 Ford F-150 Pickup Truck (A53422)
2017 Ford F-150...
2017 Takeuchi TL8 (A47477)
2017 Takeuchi TL8...
