Faucet replacement
   / Faucet replacement #11
Ideally, you'd want to heat the drop elbow enough to expand the metal but not enough to melt the solder. You could use a fresh piece of solder on the existing sweat joint to evaluate when you're getting close. When you DO get close, a cold, wet cloth on the valve body will quickly cool it relative to the elbow.
I'd be surprised if that valve can't be disassembled somehow. They had to assemble it somehow when it was manufactured.
   / Faucet replacement #12
No, there is no way to repair the faucet. Handle isn't removable. ----------------
I have never seen one with a handle that isn't removable.
Can you post some pictures?
   / Faucet replacement #14
When I'm working with copper/brass my go to wrenches are flare wrenches because they will not round off the corners like an open end wrench.
I would still try a little heat if I could do it safely...
   / Faucet replacement #15
Okay here are some pics. The handle is removable but the stem isn't. The stem rotates 1/4 turn but that's it. It will not unscrew or pull out. FYI the stem is the location of the leak.
View attachment 471728View attachment 471729View attachment 471730View attachment 471731View attachment 471732
Seeing the pictures; use bigger wrenches, don't just wrench on the valve. Make sure you put a wrench on the 90.
Also it would not be that big of deal to sweat that off and just sweat on a new drop eared 90.
   / Faucet replacement #16
Or cut it above the 90 and put on a push to connect (sharkbite or whatever).
No sweat :)
I know a lot of people swear at push-to-connect fittings but this is right out in the open so you could easily monitor it.
   / Faucet replacement #17
That valve comes apart right behind the stem take it apart and see if you can fix it .
   / Faucet replacement #19
I believe it to be a ball valve. I sell lots just like it. Thats why you can only turn it 1/4 turn. No repair replace. Sharkbite push fittings work great, Aftermarket push fittings not so much.
No sweat :)
I like the way you guys think. :thumbsup: Soldering isn't my forte. I've ordered a Sharkbite elbow and new ball valve faucet from Amazon. Should be delivered this week. The faucet is in a shed with concrete floor and drain. Even if the Sharkbite failed the damage would be minimal.
PALLET OF SCAFFOLDING (APPROX. 16 PC) (A52706)
PALLET OF...
2003 Walk-Behind Automatic Seed Spreader (A54811)
2003 Walk-Behind...
2018 John Deere 310L 4x4 Extendahoe Loader Backhoe (A52377)
2018 John Deere...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
2012 Cadillac CTS Sedan (A53424)
2012 Cadillac CTS...
2007 Hyundai Sonata GLS Sedan (A54815)
2007 Hyundai...
