Rusted nut wont budge - 48" rotary mower blade
/ Rusted nut wont budge - 48" rotary mower blade #1
Dan707
Santa Rosa, CA
1984 Ford 1910
Bought a 48" Gearmore rotary mower for peanuts and I quickly learned why. One of the blades is loose yet the nut is completely rusted solid. Ive been spraying this thing off and on with PB Blaster for over a year now. I finally gave it another good go today and snapped my breaker bar! (Had a 10ft pipe on!). Heated up the nut with MAP but didnt budge. Is this just a lost cause??
/ Rusted nut wont budge - 48" rotary mower blade #2
The only success I've had removing a nut like that is to heat the nut cherry red hot with Oxy/Acet torch the remove ith an impact gun.
/ Rusted nut wont budge - 48" rotary mower blade #3
Heat usually works, prop that torch up and let it sit for 10 minutes or so. Then attack with breaker bar or impact wrench. If that fails you might have to burn it out with a oxy/acc torch and replace nut and bolt.
/ Rusted nut wont budge - 48" rotary mower blade #4
Some stuff has left hand threads due to the shaft rotation direction. Seems to me I had a car YEARS ago that had different threads on the left and right side lug nuts... but again, I am old and feeble minded... :)
/ Rusted nut wont budge - 48" rotary mower blade #5
As said, check the thread.. but try Kroil before you give up. Kroil is better than PB blaster.
Also an impact is ALWAYS better than a breaker bar. Impacts are magic.
/ Rusted nut wont budge - 48" rotary mower blade #6
Yeah, it seems to me that some 40's plymouths were like that IIRC.....IIRC.....IIRC.....
Like kOua James said, ....if you got one, impacts are magic.
/ Rusted nut wont budge - 48" rotary mower blade #7
Another good case for acetone/atf mix.
And yes, heat till dull red. MAP torch may not be enough
/ Rusted nut wont budge - 48" rotary mower blade #8
What do you mean"One of the blades is loose"? They are supposed to be loose,and swing on the bolts.
/ Rusted nut wont budge - 48" rotary mower blade #9
I'd grind on one face of the nut until you can split it with a chisel. Then buy a new nut.
/ Rusted nut wont budge - 48" rotary mower blade #10
Or just torch it off all together.
Since the bolt and nut should be replaced anyway, and they are only about $25 a set.
But agree with Barry1, blades should be loose
/ Rusted nut wont budge - 48" rotary mower blade #11
This.
I think it's reverse-threaded.
/ Rusted nut wont budge - 48" rotary mower blade #12
I copied this from OTT.com and believe me it works like a champ.
[Machinist's Workshop MagT recently published some information on various penetrating oils. The magazine reports they tested penetrates for break out torque on rusted nuts.They are below. They arranged a subjective test of all the popular penetrates with the control being the torque required to remove the nut from a "scientifically rusted" environment.
Penetrating oils ........... Average torque load to loosen
No Oil used ................... 516 pounds
WD-40 ..................... ... 238 pounds
PB Blaster .................... 214 pounds
Liquid Wrench ...............127 pounds
Kano Kroil .................... 106 pounds
ATF*-Acetone mix............53 pounds
The ATF-Acetone mix is a "home brew" mix of 50 - 50 automatic transmission fluid and acetone. Note this "home brew" released bolts better than any commercial product in this one particular test.
ATF-Acetone mix is best, but you can also use ATF and lacquer thinner in a 50-50 mix.
*ATF=Automatic Transmission Fluid.]
/ Rusted nut wont budge - 48" rotary mower blade #13
Cool. I have three big cans of Kroil, so I'll probably wait before risking the acetone but I'm going to give that a try sometime.
To the OP, soak it in ATF/Acetone, then try turning it to the right once or twice.
/ Rusted nut wont budge - 48" rotary mower blade #14
Map gas will not get it hot enough. Use oxy act or just cut it with a cut off wheel and crack it with a chisel. Done that many times
/ Rusted nut wont budge - 48" rotary mower blade #15
The most I've ever treated a stuck nut with PB Blaster was 3 days. You've been at this for a year. Makes me think that something else is up and no amount of penetrant may help. The fact that you put a 10' cheater bar on it and broke the breaker, talks to me as well. That nut should have broken free with no penetrant with that size bar. I've put a 5' cheater on an 18" long breaker and was able to simply snap the bolts off. These were bolts that had 7/8" nuts on them and one could see rust had fused the nut and bolt together. What you show should have turned easily with a 10' cheater bar if right threaded.
If it is, I think there is enough thread to attempt to spin on another same size nut and see if it will "catch". May begin to relate what type (l or r) nut it is.
Btw, on the left side of that nut, it almost looks as if there is a weld bead there. Can't tell if its rust or otherwise.
/ Rusted nut wont budge - 48" rotary mower blade #16
The 50/50 acetone/ATF mix works well......I've loosened hundreds of old nuts on old 100 to 150 year old wagons, buggies and carriages........works great!! Once in a great while.....have to heat them but rarely.
/ Rusted nut wont budge - 48" rotary mower blade #17
I could never get ATF/Acetone to even mix. It immediately starts to separate and every U-got-tubed video I've seen shows the same thing. I've found that plain ole diesel works good. And it's pretty abundant around here. :)
/ Rusted nut wont budge - 48" rotary mower blade #18
I am sticking with my Kroil and an impact.. That and turning the nut the correct direction. :)
/ Rusted nut wont budge - 48" rotary mower blade #19
I'd try it with an impact. If you know anyone with a 3/4 drive impact try that. Worst case scenario you can remove it with a flame wrench.
/ Rusted nut wont budge - 48" rotary mower blade #20
Just get it warm enough to melt wax. Stick an old candle against the treads and let the wax melt into the threads. Let it cool and repeat a few times and the bolt will come off. You don't need to heat it red hot. Just heat it hot enough to melt the wax.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A59904)
2018 KENWORTH T680...
2012 Ram 2500 4x4 Crew Cab Pickup Truck (A59230)
2012 Ram 2500 4x4...
3015 (A56857)
3015 (A56857)
2006 Acura RL Sedan (A59231)
2006 Acura RL...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
