pressed in zerk fittings removal
   / pressed in zerk fittings removal #1
jonsstihl
Quebec, Canada
I have a few of these on my mott flail mower and some won't take any grease.
I'm assuming I can just put a vise grip on it and pull but is there a better way to remove them without trashing them.
   / pressed in zerk fittings removal #2
I've had some luck chucking them in a cordless drill and spinning them until they come out. Not always successful, and only saved less than half that I tried. Good news is they are cheap.
   / pressed in zerk fittings removal #3
Try heating them up with a propane torch then try to grease them.
Sometimes you can free them up to take grease.
   / pressed in zerk fittings removal #4
Use a slide hammer. They pop right out. An old coupling adjusted tight works on the straight ones. I say old coupling because I had to drill mine out and retap it to fit the threads on my slide hammer. On the angled fittings, use a fork attachment on the slide hammer.
If you don't have a slide hammer, a nail puller will probably work.
   / pressed in zerk fittings removal #5
CCWKen's suggestion is a good one. Don't worry about damaging the nipple as pressed in fittings should only be installed once.
Here's a pair of vice grips on my slide hammer. I didn't have a drive type press in nipple handy for the photo.
Terry
I happen to have a slide hammer that has an adapter for vice grips. I will try that thanks. Both u-joints that came with the mower shaft are missing the threaded zerks so I will get new pressed in zerks at the same time as those ones.
   / pressed in zerk fittings removal #7
I have the proper tool for installing them but an appropriately sized socket (preferably impact) can also be used to drive them in square without damaging the nipple.
Terry
   / pressed in zerk fittings removal #8
Agreed. just knock them out. They shouldn't have used those type anyways but in todays (cheap) :thumbdown:way of doing things it save the company money at your expense. Just tap the thing and put in a REAL zerk , the way they should have in the first place.
   / pressed in zerk fittings removal #9
   / pressed in zerk fittings removal #10
Terry
The last time I tried to use a socket to drive in the zerk it munged up the mouth of the socket and pretty much ruined it. I've since gotten a zerk driver tool.
As for removing the pressed in zerks... just try greasing them normally. That's when mine have always popped out on their own. :)
2017 JOHN DEERE 350G LC EXCAVATOR (A52705)
2017 JOHN DEERE...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2003 Ford F-250 4x4 Reading Service Truck with Liftgate (A53422)
2003 Ford F-250...
UNUSED Under Mount Stainless Steel Sink & Faucet (A53117)
UNUSED Under Mount...
2020 BOBCAT T770 SKID STEER (A52705)
2020 BOBCAT T770...
