Craftsman Tractor Blades
   / Craftsman Tractor Blades #11
Perhaps John Deere steel needs a thicker edge to keep from nicking. :)
   / Craftsman Tractor Blades #12
Gator blades are 30degrees with a .030mm (1/32) edge.
I changed to new blades (Oregon) I think they're called. Didn't make a lot of difference from the old blades which were about a year old. I'm getting some uneven cutting even after I checked to see that the deck was level. My manual says to have the wheels that are under the deck "just off the ground" while in the cutting height and on level ground. I set the wheels down from where they were and now I can barely get my index finger under each of the wheels. My thinking is that maybe the wheels are too close to the ground and not allowing the deck enough movement to make up for uneven ground in spots. What are your thoughts please?
   / Craftsman Tractor Blades #14
As long as the wheels are not touching the ground when you are parked you are OK. They should only touch ground when the mower rocks or dips while moving. Are the new blades perfectly flat along the cutting edge? I recently bought blades that had a small warp in them. I hammered it flat and they cut smooth again.
Thanks for the reply. Yes the blades seem flat. I took them off a "slightly" sharpened them as they were more than butter knife in thickness. I take it that the only part you sharpen as at the tips and sharpen only the bottom side of the blades. Tomorrow I'll try setting the wheels up one notch to give the deck a bit more play and see if that helps. It's very difficult to get under the deck and measure from the ground to the blades to see if they are the same distance on each side but they appear to be and in measuring the deck frame on each side to the ground are dead on if that makes sense.
   / Craftsman Tractor Blades #16
You can sharpen more of the blade but it may put greater load on the engine since you are increasing the cutting surface. I don't think it would be worth the effort. You should only be sharpening the top side of the blades. Make sure the blades are mounted correctly and not upside down. If one is mounted upside down, you will definitely have an uneven cut.
   / Craftsman Tractor Blades #17
FYI, no lawn mower blade should be 'knife sharp'. They are meant to be a little dull with a 1/32"-1/64" edge. If they are sharpened to a fine edge, the edge will simply curl and roll back very quickly anyways and result in a edge that could, and usually is, duller than normal. And you should never sharpen the bottom of the blade, only the top and keeping the correct angle. The bottom is to remain flat. Speaking of which, Oregon Gator blades use a 30* angle and a .030" (1/32"/.8mm) edge (what they cal 30-30) as opposed to the 40-45* angle and .015"(1/64"/.4mm) edge of 'normal' blades. This is why the seem to last longer between sharpening and resist dings better.
[video]https://mowhow.mowdirect.co.uk/hc/en-gb/article_attachments/200643788/totorotshrp.gif[/video]
Over the years, I have always sharpened the top sides of the blades until one of the service people of lawn tractors told me to sharpen only the bottom sides. It does make more sense to sharpen the top sides in my mind at least so I'm going back to what I've done for many years with no problems. Now I have sharpened the bottoms of these brand new blades but hopefully by sharpening the top sides a bit now may straighten this problem out. Thank you both for the very useful info. It's appreciated.
   / Craftsman Tractor Blades #19
The bottoms of my Oregon Gator blades have a grit welded onto them, so you would not want to sharpen the bottom side. I stopped using mine because the cutting edge is 3/8" lower than my stock blades. The Oregon blades dip down from the spindle and I mow my field on the highest setting, and did not want to go 3/8" lower. I switched to Max Power / Diamondback blades which are completely straight, with no dip.
   / Craftsman Tractor Blades #20
Unless your OEM blades also had the 3/8" offset, you got the wrong blades.
UNUSED MOWER KING 67" QUICK ATTACH FLAIL MOWER (A51248)
UNUSED MOWER KING...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
Lot of 2 Caterpillar Loader Tires (A51691)
Lot of 2...
2019 JOHN DEERE GATOR XUV855M 54 UTV (A51247)
2019 JOHN DEERE...
Sky Trak 10054 Legacy 10K Telehandler (A51573)
Sky Trak 10054...
