Chainsaw holder, Kubota 60 series cab
   / Chainsaw holder, Kubota 60 series cab #1
lungdoc
Gold Member
Niagara & Muskoka ON
Kubota L6060 cab, Deere 4320
Thought people would like to see a chainsaw scabbard I just made for our Grand L6060 cab. Made from spare plywood, about 18.5" long, 6" wide with 1" pieces on each side leaving a 4" channel for the blade. 2x4 to mount to existing bracket just above the washer fluid tank. For a large saw might want it lower or further out to allow roof clearance when removing but fits fine with a 16" bar on my smaller Stihl 260. Handy to have a saw along. Mounts with 1/4" x 4" bolts up top, slighlty larger and shorter down below (existing bracket was there for the safety triangle.
   / Chainsaw holder, Kubota 60 series cab #2
Are you really tall, or do you stand on a lift arm to raise the saw high enough to clear the scabbard?
   / Chainsaw holder, Kubota 60 series cab #3
I puzzled over how to mount/locate a saw scabbard on my friends L4310 cab tractor a while back. It couldn't block the rear window, as he often opens it, and couldn't mount it vertically because he has a knee problem and didn't want to climb to remove it... we never did come up with a workable solution.
Nice work on yours, I also keep a saw with me at all times.
I am 6'2" and can easily lift it out. I wouldn't want a 20" bar.
   / Chainsaw holder, Kubota 60 series cab #5
That's not a bad place, least you can see the saw when you look behind while driving the tractor, but I prefer to the side or in front, but diffidently not in the loader bucket
Nice - I did a similar one on the loader mount for our open station Deere 4320 but the Kubota doesn't have a suitable mounting spot on the loader and I didn't want to drill. Could have done it with straps I suppose but existing mount points so much easier.
   / Chainsaw holder, Kubota 60 series cab #7
I haven't gotten around to making one yet. I bought several of those 3/4" thick plastic cutting boards for the kitchen to make one but they are still sitting in the garage near the tractor. Of course I now have two saws I take into the woods so I really should make something that can hold both as well as fuel, oil, and safety gear.
   / Chainsaw holder, Kubota 60 series cab #8
How do you carry all the stuff in the woods now? I carry my gas/oil nuts and bolts this and that behind my seat.
   / Chainsaw holder, Kubota 60 series cab #9
I built 2 holders on my box blade as I always carry at least 2 saws. It is only 3' off the ground but at the end of a long day that is almost too much!! CJ
   / Chainsaw holder, Kubota 60 series cab #10
I know what you mean, lifting a chainsaw 3' off the ground at the end of any day is enough for me...........
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
2015 Ford Transit 350HD Passenger Van (A50323)
2015 Ford Transit...
New Holland TN70 Tractor (RUNS) (A50774)
New Holland TN70...
John Deere 3025E (A50120)
John Deere 3025E...
44500 (A51692)
44500 (A51692)
