UDT for bottle jack?
   / UDT for bottle jack? #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
I scored bottle jack at the pile of scrap metal, all it needed was to top the oil up, haha.
Anyway, I did not have enough oil for it so I used Kubota UDT, likely overkill :D
What do you think?
   / UDT for bottle jack? #2
What do you think?
I don't see why it shouldn't work. It is good non foaming fluid. Might be a bit pricey, but you don't need much of it.:)
   / UDT for bottle jack? #3
So is your avatar photo "Tuco Ramirez"? as portrayed by Eli Wallach?
yes :)
   / UDT for bottle jack? #5
heck.. I got a floor jack someone left at the DUMP.. said it would not make pressure. I put an oring in it from a multi kit and filled it with gear oil. that was 20 ys ago and it still works fine!
   / UDT for bottle jack? #7
I think just about any sort of oil would work. Motor oil, PS fluid, shock oil etc. Bottle jack is a pretty low-tech thing.
   / UDT for bottle jack? #8
Agreed.. Cooking oil, etc..
   / UDT for bottle jack? #14
Vegetable oils polymerize when exposed to air. That means they harden. That's not a good thing in a mechanical device.
I'll guess you didn't read any of the posts.. or understand them so I'll let that go.
The comment was that for a hyds application.. for 'function'.. just about ANY oil would work.
PS.. in a bottle jack.. there isn't much ( none) air cirulating! ;)
Kubota L4701 (A53317)
86"X18' DOUBLE AXLE TRAILER (A60430)
86"X18' DOUBLE...
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
2022 FORD F-150 XLT CREW CAB TRUCK (A59823)
2022 FORD F-150...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
FARMHAND 827 FEED MILL (A60430)
FARMHAND 827 FEED...
