UDT for bottle jack?
   / UDT for bottle jack? #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
I scored bottle jack at the pile of scrap metal, all it needed was to top the oil up, haha.
Anyway, I did not have enough oil for it so I used Kubota UDT, likely overkill :D
What do you think?
   / UDT for bottle jack? #2
What do you think?
I don't see why it shouldn't work. It is good non foaming fluid. Might be a bit pricey, but you don't need much of it.:)
   / UDT for bottle jack? #3
So is your avatar photo "Tuco Ramirez"? as portrayed by Eli Wallach?
yes :)
   / UDT for bottle jack? #5
heck.. I got a floor jack someone left at the DUMP.. said it would not make pressure. I put an oring in it from a multi kit and filled it with gear oil. that was 20 ys ago and it still works fine!
   / UDT for bottle jack? #7
I think just about any sort of oil would work. Motor oil, PS fluid, shock oil etc. Bottle jack is a pretty low-tech thing.
   / UDT for bottle jack? #8
Agreed.. Cooking oil, etc..
   / UDT for bottle jack? #14
Vegetable oils polymerize when exposed to air. That means they harden. That's not a good thing in a mechanical device.
I'll guess you didn't read any of the posts.. or understand them so I'll let that go.
The comment was that for a hyds application.. for 'function'.. just about ANY oil would work.
PS.. in a bottle jack.. there isn't much ( none) air cirulating! ;)
Booster Cables (A59230)
Booster Cables...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 Harley-Davidson FLHP Road King Motorcycle (A59231)
2021...
2004 Mack CV713 Granite Fuel and Lube Truck (A59230)
2004 Mack CV713...
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
2025 Swict 84in Bucket Skid Steer Attachment (A59228)
2025 Swict 84in...
