List of quality refurbishers?
   / List of quality refurbishers? #11
I think he used to turn hard with a full load in the FEL and possibly hit ruts, kerb's and the like at full lock to break out the bolt holes like that :eek:
   / List of quality refurbishers? #12
Yes, likely. I've had the steering wheel jerked out of my hands going backward turning, and catching a rut, causing the steering to hit its limit hard. I suspect that's what he did. And apparently he did that often. He broke both these wheels, plus one of them still has "$20=" written on it, clearly a replacement!
Just my imagination but I suspect the reason one tire is a replacement is because he made the weld repair with the tire still mounted, and damaged the tire by overheating or bursting it from weld heat.
At any rate I have flawless identical wheels cleaned, repainted, ready to put in service if I ever need them.
This tractor is infrequently used, mostly when I need the backhoe that's on it. The smaller YM186D is the one I use all the time. Buying new tires for this and mounting the new wheels is low priority.
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
24" X 36" ROLLING METAL CART (A58374)
24" X 36" ROLLING...
PALLET OF MOWER BLADES & MISC PARTS (A58374)
PALLET OF MOWER...
2011 JACK COUNTY 130BBL VAC TRAILER (A55745)
2011 JACK COUNTY...
Mini Skid-Steer Concrete Mixing Bucket (New/Unused) (A59225)
Mini Skid-Steer...
