List of quality refurbishers?
   / List of quality refurbishers? #11
I think he used to turn hard with a full load in the FEL and possibly hit ruts, kerb's and the like at full lock to break out the bolt holes like that :eek:
   / List of quality refurbishers? #12
Yes, likely. I've had the steering wheel jerked out of my hands going backward turning, and catching a rut, causing the steering to hit its limit hard. I suspect that's what he did. And apparently he did that often. He broke both these wheels, plus one of them still has "$20=" written on it, clearly a replacement!
Just my imagination but I suspect the reason one tire is a replacement is because he made the weld repair with the tire still mounted, and damaged the tire by overheating or bursting it from weld heat.
At any rate I have flawless identical wheels cleaned, repainted, ready to put in service if I ever need them.
This tractor is infrequently used, mostly when I need the backhoe that's on it. The smaller YM186D is the one I use all the time. Buying new tires for this and mounting the new wheels is low priority.
2008 TOYOTA Sienna AWD Van (A56859)
2008 TOYOTA Sienna...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A58018)
2019 INTERNATIONAL...
2006 Grove TMS900E Quad Axle 90 Ton 5 Mast Telescopic All-Terrain Crane Truck (A55973)
2006 Grove TMS900E...
2017 Polaris 500 Ranger Diesel Utility Cart (A55787)
2017 Polaris 500...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2013 Ford Edge (A54815)
2013 Ford Edge...
