Check out my new battery!
   / Check out my new battery! #61
They have no reason to fear current technology. It's not scalable to mass use. The one-off isolated user way up in the mountains (a remote radio site, for example) or the odd duck like you, are not even going to come remotely close to changing our current system. That's not even PeeWee Herman vs. Mike Tyson. It's more like a mosquito vs. Godzilla.
Mass storage, or the lack of it, is what makes every single "alternative" energy source a non-starter when it comes to fundamentally changing our energy systems. Whatever other arguments there may be for or against them, none of that matters even a tiny little bit. Mass storage (whether distributed or centralized) is the key. We don't have it, and there is nothing on the horizon that even looks promising.
I beg to differ. There is this but no one is talking about it because of politics and the economics of political power.
Energy from Thorium
It's also worthy to note that we've already done this so there is no physics only a little engineering required to put it into play. You could replace every fossil fueled heat source in existing plants with this in a matter of a few years along with as many new plants as we would ever need.
Plenty enough to get us to the day when fusion could be viable. Of course it would kill oil, coal and gas along with solar wind and all the crack pot stuff overnight. The arabs would be back on their camels and we could forget all the middle eastern mess.
I got the second set of 12 panels hooked up this morning, and will work on the third set this coming week. I need to pour 2 more footings and get that other end of the rack ready to mount them.
Flipped the breakers and smiled as the power started rolling in. 5,000 watts at 11AM.
I have need to finish the conduit and put siding on the rack, but first getting things connected and cleaning up wire is the main task.
~Moses
   / Check out my new battery! #64
~Moses
:thumbsup: Congratulations, and please keep us posted.
Rgds, D.
   / Check out my new battery! #65
This is my exact world! The best part for me is when people realize that I am basically doing everything by myself, and we started its unimproved land. It opens their eyes and so far the response has been amazing. I am at walls and in a few weeks there will be A/C then I can work past noon each day. I am too old to work in 100 degree heat so I work like a maniac until it gets too hot.
One nice thing about this forum, there are many who do it and understand completely.
Heh. And mine too. I am into year 3 on my house build. The exterior is getting to be in good shape this summer. That is my primary goal. Then maybe make a few doors this winter. We don't have any interior doors as of yet... Trim work is a distant dream... Pretty impressive the solar/battery work you did. I cannot imagine taking on that on top of the rest of the typical house build.
Its been tough, and its the little things that eat up so much time. Spending an hour and a half running to home depot for something I forgot kills the day...
The siding is on the house, and about 80% of the trim is done. I moved to the inside so the family can have a "home". This part is killing me. So much to do, and it doesn't change from day to day, even though I can spend all day working on it.
~Moses
   / Check out my new battery! #67
Ha! Tell me about it. Hours spent just trying to figure out how best to do something. Not to mention the hours spent actually doing it. And as you have noticed, the work slows down dramatically as it moves from rough to finish. A door can easily take a week to build and trim out, if you are making your own. One door. Finish work takes forever. Adjust your expectations. Especially if working solo.
Keep the faith bro!
   / Check out my new battery! #68
In case you have not thought about it, I would recommend having a pretty good stash of spare parts for the Outback stuff. If something goes wrong you can fix it your self & get back in operation much faster than waiting for replacement parts to arrive. Outback has some video's about replacing the guts of your VFX's. It's not hard, just watch the one cable they warn about. Don't ask me how I know. :laughing: Outback was very good to work with on the warranty.
I had read some stuff a couple of years ago where Outback had people do the replacements and kept their warranty in tact. I thought that was cool.
That is an excellent idea. I have the generator bypass system installed, so I can flip the breakers and feed the property direct from the generator without any of the Outback software and hardware getting in the way.
I've already discovered this with the generator... it never breaks down when I am not using it... only at 1AM on a weekend when the parts place is closed.
~Moses
   / Check out my new battery! #70
~Moses
How has the photon capturing been going on Badger Mountain ?
Rgds, D.
20703 (A51694)
20703 (A51694)
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
2025 IR IRMC 8D UNUSED Massage Chair (A53117)
2025 IR IRMC 8D...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
1994 Fontaine 48 ft. T/A Float Trailer (A53117)
1994 Fontaine 48...
