Burning Brush
   / Burning Brush #41
I have used gas already but find it is a bad way to start fires. There are to many ways to screw that mode up.
Besides the obvious like starting yourself or somebody else on fire (look at these idiots burning flags), the fire is explosively hot but don't have the sustained heat diesel fuel or motor oil have.
Unless you can dump a little gas on the pile and light it withing a second or two, the fumes may have traveled out of the brush pile and around your legs.
PS, I am glad eye brows and hair replenish themselves for cases like this.
   / Burning Brush #42
Using gas is... well.... I wouldn't even use it as a last resort.
I put diesel in a garden pressure sprayer (old one). Spray a spot, light it with my propane/map torch. Once started I can stand back and feed it more fuel to fire it up or, can "walk" the flames to other areas. When I fill my backhoe or tractor with diesel (using the Mr. Funnel), there is always a bit left that also has the sediment in with it. I use this leftover to fill the garden sprayer can.
   / Burning Brush #43
If your going to use gas a safer way to light it is to use a bb gun.
just put a wooden match , sulfer end first, in the end of the barrel,
the bb lights the match, and throws it 20 feet or so.
Might want to practice a bit first, but it works.
Rich
As kids, we had hours and hours of fun with our cheap spring-powered pellet rifles and self-lighting matches. Put them in the muzzle stem first (no pellet, just air). The head was just big enough to not go down inside the barrel (.177). Then we'd have contests to see who could shoot straight vertical enough that they would come down head first on the street pavement and ignite. They'd go up at least 100ft, probably way more. I seem to remember 5-10 seconds of "flight" time. It's more difficult than you might think to shoot STRAIGHT up! There's nothing to aim at, so it's totally instinctive. I'm sure we'd be arrested doing it today.
   / Burning Brush #44
A little off the subject, not much, but a little.
When I was much younger and much, much dumber we had just bought our first house. It was the fall of 1978. We had several trees and my wife insisted we rake all the leaves and get rid of them. Now I grew up on a farm but we never raked or burned our leaves. Either the wind blew them away or they got mowed up the next year. Nobody in the family had time to rake leaves. It seemed like we spent a week raking leaves and dragging them on sheets to the back yard. Remember, I was much dumber. Our backyard at the time was wide open in the center with a few trees on the edges, so the leaves were piled up in the open area in the center. The neighbor was also raking his and because he didn't have a good place to burn I invited him to put his on our pile. I was trying to be friendly with the newly met neighbors and my wife thought it was a good idea. Remember the dumber part! It had rained a day or so into this odyssey so we had a pile of damp leaves about thirty feet in diameter and two to three feet high in the center. We tried to light them one afternoon and they would not burn. So I came up with the brilliant idea that a little gasoline would start the fire. I had enough sense to make sure the place I had tried to start earlier was completely wet down. Had a garden hose on the ground nearby. I explained to my wife that I would pour a little gas in the leaf pile, rake leaves over it, and pour a path back for her to drop a match on. I explained about fumes in clothes and that she had to let me get far away. So I'm out there in the middle and poured about a cup of gas out and she walks up and starts striking a match. I had a fit. Get back, get back, you're gonna get me burned. Hurt her feelings a little but she stepped back. And I poured a little more gas. She started to strike another match and I yelled at her again to stop. Lost my place there so I poured a little more gas on the pile not really watching what I'm doing but watching her. Took the rake and raked the leave around a little to cover the gas up. I was really dumb back then. Started pouring a trail back to her explaining that she needed to give me time to get away from the pile in case there were fumes in my clothes. Wasn't watching her but I heard the match strike and I threw the gas can as far as I could as she dropped the match.
Now we were ten or fifteen feet from the edge of the pile when the match was dropped. The entire pile of leaves exploded rattling windows all over the neighborhood. I had on jeans but she had on shorts. Let's just say that she didn't have to shave her legs for a couple weeks.
In my not watching what I was doing I had probably poured a gallon or more of gas on the pile of wet leaves. Raking them after the gas was poured and walking around on the pile while I argued with her had spread the fumes around and that entire pile burned in about thirty seconds with flames and burning leaves ten to twenty feet in the air. Luckily the ground was wet and the wind was still and we burned nothing else down. Around us there was just a flash of flame. How we escaped serious injury I do not know because we both stood there for a few seconds until the heat made us turn and run.
I do not use it to burn but if I must use gas to get wet brush burning I use a measuring cup that shows 1/4 cup and I fill it half full. But that is a very, very, last resort.
And I make sure I am the one throwing the match.
RSKY, now much older and not so dumb.
   / Burning Brush #45
I used to push an old tire down into the center of a wet or green pile to get it started. Don't do that much anymore as scares the neighbors who live nearby.
New ideas on here I'll have to try.
Sprayer with diesel in it.
Toilet paper roll soaked in diesel.
   / Burning Brush #46
What's wrong with charcoal lighter fluid? Or the briquettes saturated with it? Gasoline is dangerous.
   / Burning Brush #48
It's not wasted. It's used. Why waste gasoline and burn your eyebrows off?
Plus, charcoal smells good burning and you could grill some meat as the fire gets going.
   / Burning Brush #49
Eyebrows that's why I don't use gas anymore. Diesel is now used don't have the flash like gas.I save charcoal for the grill!!!
   / Burning Brush #50
Gas is cheaper then diesel or charcoal lighter fluid.
2013 FRAC TANK (A53843)
2013 FRAC TANK...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52706)
KNOW BEFORE YOU...
2021 M&J PRESHRED 4000M SHREDDER (A53426)
2021 M&J PRESHRED...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
