hosspuller
- Joined
- Oct 9, 2008
- Messages
- 1,786
- Location
- Piedmont Triad, NC
- Tractor
- Didn't intend to have a Deere fleet - it just happened 310C, F915,102, 5200 & 5065E
Interesting.
If I had to guess, I'd say that helps with the blades being balanced so you don't get as much shuddering, but I'd say that with the blades fully extended it also (slightly) increases the shock and amount of torque required to bring the blades up to speed.
Actually I would say extending the swinging blades out would DECREASE shock & toque because at initial movement, the blades will rotate backward from their inertia. For a distance of about a blade length at the blade pivot, the blade mass is acting closer to the gearbox. Only after centrifugal force overcomes friction and air resistance does the blade move to full extension.
