1610d with leaking front hubs: Worst case scenario to repair?
   / 1610d with leaking front hubs: Worst case scenario to repair? #11
I put several bottles of it in mine.. It didn't work.. The STP did the trick
   / 1610d with leaking front hubs: Worst case scenario to repair? #13
Not sure why. The 4wd models generally have the 160 and the 2wd the 140. I'm assuming the 140 is better than the japan VN loader that a lot of them have?
It is a Zen Noh branded 3110d so I'm guessing it didn't come into the states with a loader and the importer put a 140 on it. Unless they sell Koykers in Japan. They are made in South Dakota.
some of them were imported actually as zen noh
   / 1610d with leaking front hubs: Worst case scenario to repair? #14
The Zen Noh story hasn't been told recently. In case someone hasn't seen it:
Zen Noh is a big ag co-op in Japan. Yanmar private-branded tractors that were sold through this co-op. The tractors are otherwise identical to standard Yanmar models.
   / 1610d with leaking front hubs: Worst case scenario to repair? #15
About a dozen years ago a network of dealers tried to import the Zen Noh tractors and say that they weren't Yanmars. I forget exactly why they wanted to do that, but a lawsuit by Yanmar put an end to it after a year or so.
That was the year that I bought my tractor, and I ended up with one of the Zen Nohs.
   / 1610d with leaking front hubs: Worst case scenario to repair? #16
I had a leak on left side of my 186D a few years ago.......used the power steering fluid.......worked for a couple years......eventually replaced seal. I am a DIY guy.....bought the parts from Hoye....pretty easy fix. Good luck.
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2014 Freightliner M2 106 AWD Altec DM48BTR Insulated Digger Derrick Truck (A55973)
2014 Freightliner...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
PALLET OF MISC LIGHTS, VENTS, & TOWBAR (A58374)
PALLET OF MISC...
2006 Utility Trailer MFD. T/A 32FT Dry Van Trailer (A56858)
2006 Utility...
