Opening up land for a garden and orchard
   / Opening up land for a garden and orchard #1
BCrouse
PA
Kubota MX5200
Ive recently started opening up land for a garden. I used a 5' bush hog. It did a pretty decent job with the 3-4' high weeds and saplings.
(Dog had to get into the pic. Thanks buddy)
My question is, should I take the landscaper rake to all that dried debris first, then plow or plow first then run the landscaper rake over it? (Yes I cleaned the dog poo up)
I just picked up a 14" (pretty sure its a 14, haven't measured it) single bottom plow that should do a pretty good job of turning the soil over. Still working on cleaning it up. Needs a bit of paint.
I haven't cleared any land for the orchard yet. Suggestions on land prep?
   / Opening up land for a garden and orchard #2
Ive recently started opening up land for a garden. I used a 5' bush hog. It did a pretty decent job with the 3-4' high weeds and saplings. (Dog had to get into the pic. Thanks buddy) My question is, should I take the landscaper rake to all that dried debris first, then plow or plow first then run the landscaper rake over it? (Yes I cleaned the dog poo up) I just picked up a 14" (pretty sure its a 14, haven't measured it) single bottom plow that should do a pretty good job of turning the soil over. Still working on cleaning it up. Needs a bit of paint. I haven't cleared any land for the orchard yet. Suggestions on land prep?
I would keep running the bush hog over the garden area till everything is all chopped up. Then let it rot for a week or two and then bush hog again. Should plow no problem. The only issue you may run into is those "saplings". Depending on the size they could hang a plow up.
Any thoughts on the landscaper rake?
Also, do my pictures show up? I do not see them.
   / Opening up land for a garden and orchard #4
Pictures not showing, says "invalid attachment"
   / Opening up land for a garden and orchard #5
Any thoughts on the landscaper rake? Also, do my pictures show up? I do not see them.
I don't think it's necessary if everything gets chopped up well by the bush hog.
Yah I think my deck wasnt level and it didnt chop as good as it should have. Im gonna have to do it again if I dont plow it over soon
Redid the pics. See if they work now
Should I start looking for a disc harrow or rototiller as a "follow up" to plowing?
   / Opening up land for a garden and orchard #9
Brush hog it one more time, plow it, disc, then run a spiked tooth drag or your landscape rake for your final seed bed.
Or rototill then follow up with your landscape rake.
   / Opening up land for a garden and orchard #10
Remove the coulter blade from the plow,, the debris will just roll under the coulter, lifting the plow out of the ground.
A coulter is normally only useful when fine roots are present, like grass or wheat,,, etc.
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
Ford F-450 Utility Truck (A55218)
Ford F-450 Utility...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
2011 International WorkStar 7300 Acid Tanker Truck (A52377)
2011 International...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
