Opening up land for a garden and orchard
   / Opening up land for a garden and orchard #1
BCrouse
PA
Kubota MX5200
Ive recently started opening up land for a garden. I used a 5' bush hog. It did a pretty decent job with the 3-4' high weeds and saplings.
(Dog had to get into the pic. Thanks buddy)
My question is, should I take the landscaper rake to all that dried debris first, then plow or plow first then run the landscaper rake over it? (Yes I cleaned the dog poo up)
I just picked up a 14" (pretty sure its a 14, haven't measured it) single bottom plow that should do a pretty good job of turning the soil over. Still working on cleaning it up. Needs a bit of paint.
I haven't cleared any land for the orchard yet. Suggestions on land prep?
   / Opening up land for a garden and orchard #2
Ive recently started opening up land for a garden. I used a 5' bush hog. It did a pretty decent job with the 3-4' high weeds and saplings. (Dog had to get into the pic. Thanks buddy) My question is, should I take the landscaper rake to all that dried debris first, then plow or plow first then run the landscaper rake over it? (Yes I cleaned the dog poo up) I just picked up a 14" (pretty sure its a 14, haven't measured it) single bottom plow that should do a pretty good job of turning the soil over. Still working on cleaning it up. Needs a bit of paint. I haven't cleared any land for the orchard yet. Suggestions on land prep?
I would keep running the bush hog over the garden area till everything is all chopped up. Then let it rot for a week or two and then bush hog again. Should plow no problem. The only issue you may run into is those "saplings". Depending on the size they could hang a plow up.
Any thoughts on the landscaper rake?
Also, do my pictures show up? I do not see them.
   / Opening up land for a garden and orchard #4
Pictures not showing, says "invalid attachment"
   / Opening up land for a garden and orchard #5
Any thoughts on the landscaper rake? Also, do my pictures show up? I do not see them.
I don't think it's necessary if everything gets chopped up well by the bush hog.
Yah I think my deck wasnt level and it didnt chop as good as it should have. Im gonna have to do it again if I dont plow it over soon
Redid the pics. See if they work now
Should I start looking for a disc harrow or rototiller as a "follow up" to plowing?
   / Opening up land for a garden and orchard #9
Brush hog it one more time, plow it, disc, then run a spiked tooth drag or your landscape rake for your final seed bed.
Or rototill then follow up with your landscape rake.
   / Opening up land for a garden and orchard #10
Remove the coulter blade from the plow,, the debris will just roll under the coulter, lifting the plow out of the ground.
A coulter is normally only useful when fine roots are present, like grass or wheat,,, etc.
2017 Ford Escape SUV (A59231)
2017 Ford Escape...
Kubota M125X (A60462)
PumpJack Brand Pump Jack (A56438)
PumpJack Brand...
2014 Ford Edge SUV (A56859)
2014 Ford Edge SUV...
2017 Ford F-550 4x4 Ext. Cab Mason Dump Truck (A59230)
2017 Ford F-550...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
