Oil & Fuel Fuel light on all the time. Runs out of fuel with quarter tank showing.
   / Fuel light on all the time. Runs out of fuel with quarter tank showing. #1
Mad Mac
Gold Member
Grapeland, TX
Mahindra 5555
When you look into the tank there still seems to be fuel. It's a minor inconvenience but is there an easy fix?
   / Fuel light on all the time. Runs out of fuel with quarter tank showing. #2
Sounds like a problem with the pickup tube?...Bent?
   / Fuel light on all the time. Runs out of fuel with quarter tank showing. #3
I'd say it's more likely that the level sensor isn't calibrated correctly. It's usually just a pot on a swinging arm with a float.
   / Fuel light on all the time. Runs out of fuel with quarter tank showing. #4
If there is actually fuel in the tank, then it's not an issue with calibration. If the OP is mistaken, and the fuel is actually pretty much gone, I'd agree with this assessment.
OP, how much fuel does it take to fill the machine back up completely when it runs out - and how does that amount compare to the stated capacity of the fuel tank?
My operator uses a 5-gallon diesel jug to refill. It holds 12. I'll check with him tomorrow.
Thank you one and all, but a fix does not sound simple.
   / Fuel light on all the time. Runs out of fuel with quarter tank showing. #6
I don't have a working fuel gauge on any of my tractors. But... I do have a wood stick. :) It's about 3/4"x1/2" and 18" long. It's more accurate than any fuel gauge when determining 1/4 tank increments.
   / Fuel light on all the time. Runs out of fuel with quarter tank showing. #7
If you ever have to restart a big diesel (I'm talking 671 Detroits), you will NEVER let that thing get below a 1/2 tank EVER again. This happened to me when I had to take over for an operator on a huge Euclid dump truck that went home sick (I was 19 and I'm 66 now...). Took me 3 hours to get it to "catch"....Keep them filled....BobG in VA
Sensible suggestions. Thank you.
Okay. It takes a little more than 10 gallons to top off the 12 gallon tank. So the calibration is off. We just need to refill it before it gets down to a quarter of a tank.
IH 810-10 Pick Up Head (A50514)
IH 810-10 Pick Up...
2015 FREIGHTLINER M2 DAY CAB (A51222)
2015 FREIGHTLINER...
2013 Ford F-150 Ext. Cab Pickup Truck (A50323)
2013 Ford F-150...
1996 Lincoln Town Car Sedan (A50324)
1996 Lincoln Town...
2013 CATERPILLAR 320EL EXCAVATOR (A51242)
2013 CATERPILLAR...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
