Oil & Fuel Fuel light on all the time. Runs out of fuel with quarter tank showing.
   / Fuel light on all the time. Runs out of fuel with quarter tank showing. #1
Mad Mac
Gold Member
Grapeland, TX
Mahindra 5555
When you look into the tank there still seems to be fuel. It's a minor inconvenience but is there an easy fix?
   / Fuel light on all the time. Runs out of fuel with quarter tank showing. #2
Sounds like a problem with the pickup tube?...Bent?
   / Fuel light on all the time. Runs out of fuel with quarter tank showing. #3
I'd say it's more likely that the level sensor isn't calibrated correctly. It's usually just a pot on a swinging arm with a float.
   / Fuel light on all the time. Runs out of fuel with quarter tank showing. #4
If there is actually fuel in the tank, then it's not an issue with calibration. If the OP is mistaken, and the fuel is actually pretty much gone, I'd agree with this assessment.
OP, how much fuel does it take to fill the machine back up completely when it runs out - and how does that amount compare to the stated capacity of the fuel tank?
My operator uses a 5-gallon diesel jug to refill. It holds 12. I'll check with him tomorrow.
Thank you one and all, but a fix does not sound simple.
   / Fuel light on all the time. Runs out of fuel with quarter tank showing. #6
I don't have a working fuel gauge on any of my tractors. But... I do have a wood stick. :) It's about 3/4"x1/2" and 18" long. It's more accurate than any fuel gauge when determining 1/4 tank increments.
   / Fuel light on all the time. Runs out of fuel with quarter tank showing. #7
If you ever have to restart a big diesel (I'm talking 671 Detroits), you will NEVER let that thing get below a 1/2 tank EVER again. This happened to me when I had to take over for an operator on a huge Euclid dump truck that went home sick (I was 19 and I'm 66 now...). Took me 3 hours to get it to "catch"....Keep them filled....BobG in VA
Sensible suggestions. Thank you.
Okay. It takes a little more than 10 gallons to top off the 12 gallon tank. So the calibration is off. We just need to refill it before it gets down to a quarter of a tank.
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2023 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2023 Ford F-150...
2011 FORD F-250 (INOPERABLE) (A50854)
2011 FORD F-250...
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
2011 Cadillac DTS Sedan (A50324)
2011 Cadillac DTS...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
