newbury
Super Star Member
- Joined
- Jan 8, 2009
- Messages
- 14,187
- Location
- From Vt, in Va, retiring to MS
- Tractor
- Kubota's - B7610, M4700
In another thread I tried to ask which product or mix was best, meaning to allow one to spray on the chemicals and spray off the crud WITHOUT SCRUBBING. In my case the crud is almost exclusively algae, much of it out of reach for scrubbing even with extensions.
But the replies were:scrub, just use water, and blew an engine. So I'll try again.
What's the best solution (as in mix of chemicals)?
Opening of the other thread:
First proposed mix:
And my question on the other thread.
Has anyone tried more than one of these mixes and been able to compare them?
I would dislike buying a gallon of Jomax, adding a gallon of bleach and just after I finish someone posts great success with bleach and spit.
North side is green again . What is a good presoak before blasting ?
First proposed mix:
This gets good reviews on Amazon, but is expensive, $48/gallon and requires adding bleach. Note that JD855, quoted down below just uses bleach.I have used Jomax siding wash with great satisfaction. Wish I had discovered it sooner, it saves a lot of time. It is a concentrate that gets mixed with bleach and water and can be applied with a garden sprayer.
Amazon.com: RUST-OLEUM 60104 Jomax house cleaner and mildew killer: Home Improvement
Again, some good reviews, less expensive than Jomax ~$18/gallon but has it's own bleach.I just finished and used:
Home Armor
E-Z House Wash
Mold Stain Remover
Bought at Lowes.
Shop Mold Armor 56-fl oz Liquid Mold Remover at Lowes.com
Let it soak a few minutes and rinse. Reading the cleaning instruction online for my paticular vinyl it said no more than 1500 psi and shoot in a downward direction, that's why I just attached a hose to the nozzle on the bottle. The cap has a Clean/Rinse/Close nozzle.
Siding looks new.
Reads like a good DIY mix, very inexpensive.I use a cup of powder laundry detergent, big squirt of dawn dish soap, and about 2 cups of pool shock (12% bleach) mixed in a 5 gal bucket with water, then feed into the pressure washer soap injector. Spray it on, let it sit for a minute, and hose off. Do not need high pressure to rinse, which is good. That is the worst thing for a house. Never use a high pressure nozzle directly on your house! I use the soap nozzle to spray the soap on, then use a "2nd story" nozzle to get water up for rinsing.
This is advertised for removing grease, but only costs $9/gallonWhile trying to clean up my new to me motor home that had mildew and black mold all over it plus the canopies were all moldy from being stored wet. My neighbor turned me on to a product available at Walmart called SUPER CLEAN. It is a strong detergent with bleach and it isn't terribly expensive. I used a garden sprayer to wet the siding down first, let it set for a few minutes then hosed it off. All but the worst spots hosed off without scrubbing. Stubborn spots took some scrubbing with a car wash brush. The canvas was wet from both sides, allowed to set for several minutes, scrubbed with the brush and it came out looking like new. I used it full strength buy you can dilute per container directions for less funky areas.
Can't get cheaper. Poor man's JOMAX, which you have to add bleach to.I use 50% household bleach and water in a bleach safe sprayer. If it doesn't say bleach safe on the sprayer label you will be replacing it.
Spray it on, let sit, hose it off. Repeat as necessary.
Again, reads like a good DIY mix. But note even cheap bleach tells the concentration on the label.I use the following solution with a pump sprayer. I hose it off with a pressure washer from about 3 feet away. I don't want to blast the siding. The pressure washer uses less water than my low pressure high volume garden hose.
Solution:
3 quarts warm water
1 quart bleach (use the good bleach like Clorox. Generic bleaches are not as concentrated. look for a 5% solution)
2/3 cup TSP (The real stuff not the phosphate free)
1/3 cup household detergent. ( I use Tide liquid laundry detergent)
I usually scale up the recipe to make 4 gallons in a 5 gallon bucket. Work from the bottom up or you will get streaking.
Has anyone compared the different solutions offered here? Just got my HD $100 PW and looking for the best solution.
