John Deere X380 vs Husqvarna GT52XLS
Status
Not open for further replies.
   / John Deere X380 vs Husqvarna GT52XLS #11
X380 won't have a better Kawi than the Husqvarna, but nearly everything else will be better except the transmission - but the K58 is still a stout unit. Husky will have a far better GT available next year with a far better deck (48") that does not require a Powerflow unit to bag - but still bags just as well as one. Kawi engine, Tuff Torq K66 unit with electric locking diff, under $3k.
Still, the JD will hold value longer down the road, and simple things like steering will be smoother and last longer before repairing. Frame will be stiffer, deck lift mechanism easier to operate, and better gauges on JD - including a fuel gauge which I'm partial to. Kills me that my GX335 doesn't have one!
X380 won't have a better Kawi than the Husqvarna, but nearly everything else will be better except the transmission - but the K58 is still a stout unit. Husky will have a far better GT available next year with a far better deck (48") that does not require a Powerflow unit to bag - but still bags just as well as one. Kawi engine, Tuff Torq K66 unit with electric locking diff, under $3k. Still, the JD will hold value longer down the road, and simple things like steering will be smoother and last longer before repairing. Frame will be stiffer, deck lift mechanism easier to operate, and better gauges on JD - including a fuel gauge which I'm partial to. Kills me that my GX335 doesn't have one!
Now that's the kind of feedback that I was expecting out of this forum. Thanks!
   / John Deere X380 vs Husqvarna GT52XLS #13
I would look forward to a better Husky GT...do you know if the TT K66 with "electric" locking diff is the "auto engage diff lock...or you engage when you want/need? I do not want an auto engage. Your description sounds great...Kawi/TT K 66 with diff lock/better 48" deck/under $3K. Do you have a good source for this? When expecting to be introduced? Model #...Thanks...TMR
   / John Deere X380 vs Husqvarna GT52XLS #14
It is a GT48DXLS, electric via dash toggle like the current GT lockers.
It started 2 years ago with the 42" clear cut deck on the YT42DXLS, solving a problem on the 3-blade 42" fab deck reverting it back to 2 blades which made for a fantastic cutting deck. Notice Deere released "Accel Deep Decks?" Same concept. Husqvarna moved forward with their 48" model this year being available on the GT48, YT48DXLS, and Z248F zero turn.
My only beef with these tractors (this is where I forget the price range of these things) is the steering system. They need a bigger steering wheel, different ratio - something to make an easy feeling turn.
Consumer info likely won't be released until 2017.
I'm a dealer, that's my source lol
   / John Deere X380 vs Husqvarna GT52XLS #15
Not to split hairs, But I think you should let Kawasagi know that there is no difference in FR and FS engine series. The husky uses a Kawi FR series engine ( Kawasaki FR730V) The X380 uses the FS series (Kawasaki FS651V) The FS is next “step up” in Kawasaki engines . As for transmission, again I’m going to disagree the on tranny’s the K58 ( 217 foot pounds of torque) and Hydro-Gear G7( 230) are very similar spec wise. If you want to give a Hydro gear a slight edge- I guess so but I’d add Tuff Torq is the more established company with far more installed units than Hydro gear
I do agree just about everything else is better on the X380, ease of steering, Better frame, better mowing deck and far superior re sale value
And again I’m not bad mouthing the Husky- but there is a reason why the X380 costs more- it’s a far superior lawn tractor
Google bent frame on Husqvarna GT52XLS or poor cut quality and you’ll see what I mean
   / John Deere X380 vs Husqvarna GT52XLS #16
I bought JD X380 this spring. I also have two acres to cut. I have a lot of trees, patio stone lined flower beds, little bit of inclines, a landscape mound that is about 100' long, about 10' wide and about 5' tall. I have a 54" deck on it. I was cutting before with a Skags 48" walk behind. Took 2 hours with the Skags and I walked at a decent clip for 6 miles. Just got tired literally of all the walking. I can cut the same area now in 1 1/2 hours. I have an open area that is about an acre that is a bit bumpy. The machine cuts nicely, as long as you adjust the anti scalp wheels like they tell you in the manual. The left pedal that lifts and lowers the deck is a lot easier than a lever. Parking brake is easy also. The seat moves back and forth and also has three different positions for the springs, which changes the way it rides depending on your weight. I wouldn't buy a gas engined mower that wasn't a Kawasaki, love their engines. Fuel injection is spot on, gas filler is big and in a nice location on the left rear corner. The 54" deck is as big as I could go and still fit in between some fences and flower beds. The extra 6" over the Skags 48" makes a very noticeable difference. I like the gas gauge and it has the hour meter and pto rpm gauge too. My favorite feature is the magic yellow button that lets you go in reverse with the pto engaged and keep cutting. Works like a champ. You don't have to hold it in the whole time, just push it rit before you step on the reverse pedal. Once you hit the forward pedal, it resets itself. The tractor seems to be built pretty well. I did a lot of looking, reading, and research before buying this. Most of the other machines in this size are not made to last, course they are priced cheaper, but I don't like throwaway stuff. I also bought at about the same time a JD2032 with a front end loader and a backhoe, for maintaining the property. I still have to get a brush hog, York rake, and box scraper. Bought them both from the same dealer, who gave me a very good deal and seemed very knowledgable. Hope this helps, any questions, feel free to ask.
Mike Hawkins
   / John Deere X380 vs Husqvarna GT52XLS #17
Nice setup Mike
   / John Deere X380 vs Husqvarna GT52XLS #18
Not to split hairs, But I think you should let Kawasagi know that there is no difference in FR and FS engine series. The husky uses a Kawi FR series engine ( Kawasaki FR730V) The X380 uses the FS series (Kawasaki FS651V) The FS is next 都tep up in Kawasaki engines . As for transmission, again I知 going to disagree the on tranny痴 the K58 ( 217 foot pounds of torque) and Hydro-Gear G7( 230) are very similar spec wise. If you want to give a Hydro gear a slight edge- I guess so but I壇 add Tuff Torq is the more established company with far more installed units than Hydro gear
And again I知 not bad mouthing the Husky- but there is a reason why the X380 costs more- it痴 a far superior lawn tractor
Google bent frame on Husqvarna GT52XLS or poor cut quality and you値l see what I mean
The kawi fs may have a different carb and a foam wrap around the air filter. I've done IPL side by side comps and there are extremely few differences. Another may be a metal screen over flywheel vs plastic. Valves, rods, pistons, block, crank, the same parts.
Never meant to say the husky gt was a better tractor, just that its quite the machine for the money - kawi, locking k66 trans, solid 48" deck, $3k price tag. They are getting better every year, its only a matter of time before steering and frame get addressed, that's what they lack the most IMO vs the x series.
   / John Deere X380 vs Husqvarna GT52XLS #19
Have had the JD X380 for a few months. Very nice machine. Got it at JD dealer. Replaced my Husqvarna LGT2654 that I want to replace the transaxle with a K66 and use as a tractor instead of a mower.
   / John Deere X380 vs Husqvarna GT52XLS #20
tk tom - any info on availability of the GT48DXLS? It's not at my local dealer (Ace HW) yet.
Thanks
Status
2019 FREIGHTLINER CASCADIA (A52577)
2019 FREIGHTLINER...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
2014 RAM 4500 versa LIFT bucket truck (A52377)
2014 RAM 4500...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A53472)
2013 Doyle Dry...
