Rod in Forfar
- Joined
- Apr 10, 2010
- Messages
- 582
- Location
- Forfar, Ontario, Canada
- Tractor
- 1960 Massey Ferguson 35 (Perkins), 1995 TAFE 35DI, 1980 Bolens G174, 2005 Kubota B7510, 2020 Kioti Mechron 2200ps UTV Troy-Bilt Horse 2 1988 Case IH 255 4WD with loader and cab
My first try involved crawling under the bush hog with a pipe wrench and a 4' pipe. Not a happy experience.
A few years later I learned to remove the bush hog from the tractor and suspend it by logging chain from a front-end loader. Lower it to the ground enough to prevent undue movement. Block rotation with a convenient stick from a nearby woodpile. Then have at it with the heavy ratchet with a 4' pipe attached. It works quite well. Just don't touch the nut for a while after removal as it will be quite warm. While you're in there, tighten the nuts fastening the gearbox to the frame. They come loose over time.
