Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #3,771
Had a couple of big maple trees taken down last year.. Now they're this years firewood.. Unfortunately my 16 year old Husqvarna 365 Special gave up it's compression halfway through the pile :(
   / Tractors and wood! Show your pics #3,774
I'm going to, just waiting for a couple of parts..
I'm pretty sure you can put a 372 piston and cylinder on it. The cylinders are not too pricey at the dealer.
   / Tractors and wood! Show your pics #3,775
Have you had any problems with your Hydric hoses getting snagged on stuff ? The ones from the loader?
Someone said something about mouthfuls. Worked on a large silver maple still have to finish cleaning it up. That is a 36" bar on that 660
   / Tractors and wood! Show your pics #3,776
Have you had any problems with your Hydraulic hoses getting snagged on stuff ? The ones from the loader?
no but i did run over a sapling that then engaged the PTO
   / Tractors and wood! Show your pics #3,778
i was using the grapple to clear some small saplings and i managed to get one under the tractor and when i went to back up the sapling wedged itself against the cable that runs to the lever to engage the PTO and pull on it and the PTO started up it was a little disconcerting until i figured out what happened
   / Tractors and wood! Show your pics #3,779
I've been looking at a John Deere 5055e 2016. Do you recommend this tractor? what would you get different on it if you had to do it again?
   / Tractors and wood! Show your pics #3,780
Yesterday I started cutting some doomed white pine to salvage the logs out of them before they die. Like this one which has a big Blister Rust canker. It was right against the power line too.
EDIT: Still can't do vertical pics I guess. The bottom is to the right the top to the left.
And the stump had carpenter ants in it. There were two tunnels showing in the butt so I set it up on the stump so I could trim it off and keep the saw out of the dirt. I was lucky and only needed to trim 4".
Got 3 logs out of it.
gg
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A55301)
LIKE NEW 2023...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A54814)
2021 International...
Galvanized Steel Fence 10ft x 7ft (A55758)
Galvanized Steel...
2013 HYUNDAI 40DS-7E STRAIGHT MAST FORKLIFT (A51406)
2013 HYUNDAI...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
