Dam Failure - Any Suggestions?
   / Dam Failure - Any Suggestions?
An acre pond ~5' average depth is only about half the water you think. About 1.6M gallons.
A 100' roll of 6" solid drain tile is ~$100. That would flow alot of water. About what a 4" trash pump would but would consume no power.
If the water is close enough to where the discharge is gonna be, you can cut that 100' roll in half and have two siphons going. At ~25000 gph each, and two of them going....should be able to lower the water level about a foot every 6 hours.
The only issue with plastic tile is that it floats. SO you will need to do something to hold the end under the water.
I have seen several others suggest/ask, but never seen a response. What does the pond have currently, for overflow protection?
Right now the pond has an 8 inch overflow pipe. Looks like the pipe got clogged during the storm, which caused the water to surge over the dam. I know that the dam was not constructed propel now - its pretty evident based upon this failure. It was installed a long time ago by a previous owner.
   / Dam Failure - Any Suggestions? #22
Well, they must have done something right if it was indeed constructed "a long time ago".
Nothing last forever without upkeep. It seems perhaps everything would have been fine if the overflow didnt plug up?
HAve you cleared the overflow yet? and let that 8" pipe drain the level down at least to where it should be? That single 8" should flow as much as a pair of 6" pipes.
   / Dam Failure - Any Suggestions? #23
That is the reason pond construction in my state doesn't allow for a pipe overflow. They claim (and quite correctly) that a pipe cant be sized to handle unexpected overflow conditions. The overflow must be constructed on the upper end of the pond and a drainage channel built to channel the water around the pond dam toward the lower elevation end. When constructed correctly, the pond can fill to within inches of full dam height and then water will flow out the overflow from the high elevation, around the side of the pond and out thru the overflow channel. This might just be a grass covered swale or if the pond is larger, a rocked in swale to prevent erosion.
When we bought our property, there was 2 ponds already on it with pipe overflows. Large rains would wash over the dam creating erosion on the dam that had to be repaired several times. We decided to raise the dam height (during a drought that almost dried up the pond) using dirt from digging out the pond. We raised the dam height by about 2 feet, then added the state required upper elevation overflow. We kept the 12" overflow pipe that starts running when the pond reaches about 14" from top of dam. When that pipe cant handle the flow from heavy rains, the upper end overflow will start discharging when the water level reaches about 4" from flooding the dam. It is wide enough that only during super storms have we had a breach on the dam. I rocked the area that floods during one of those 100 year rain storm so if it does overflow the dam, it doesn't wash any soil out.
The overflow runs about 20 feet from the bottom of the pond levee and at times it looks like a small river running down thru my lower portion of lawn. So far the grass keeps it from washing.
We had another pond constructed per state requirements and it has no pipe overflow only the swale from the upper end. We came back after the state inspection and raised the swale overflow elevation about 3 feet so the pond would fill up more. The swale is about 20 feet wide so it will handle a lot of water. The pond has never overflowed the dam and the resting level is only about 6" below full capacity.
Well we were able to get the over flow pipe unplugged, which is helping quite a bit. I also got a 4 inch pvc siphon going. I'll probably end up putting together another one this afternoon. Hopefully we can get the pond safely drained in a few days.
   / Dam Failure - Any Suggestions? #25
That is great news. We did not get the rain that was forecast yesterday but it looks like there is a bit of rain out there today so hopefully you can get the pond drained to a safe level soon. The siphon was a great idea from the TBNers. :thumbsup::thumbsup::thumbsup:
The latest weather model says we have about a week before that low/Hurricane gets near NC. Hopefully, the model is wrong and that storm heads out more to the east. Hopefully, in a week you can drain that pond to a safer level.
Ironically, I drive by an old farm pond that is maybe 20 feet above a high way. The farm was sold long ago and houses are now being built which has caused quite a bit of run off and other issue. :rolleyes: A year or so ago I saw water running over the top of the dam. :shocked: I called up the state dam engineer and he went out to have a check and that problem was fixed. If that dam had failed a major north/south road would have been destroyed which would have made travel a HUGE mess.
I noticed yesterday there was a couple pallets with bags and some other stuff dropped off near the dam. This morning they had guys about to start doing something. I am wondering if they were going to be putting in some bentonite. The dam is in a curve so it is hard to get a good look but it sure looks like there is water leaking at the bottom of the dam. :shocked:
   / Dam Failure - Any Suggestions? #26
The problem around here is ponds silting up with heavy rain... several local ponds are just about no more...
They can be fine for years but don't handle days of rain well...
Yeah - I'm really hoping that the rain holds off for a while longer. My wife and I were never fans of the dam or the pond - so we aren't to sad to see it go. We just want to make sure that the pond water is released in a controlled and safe manner.
Here is the siphon pump that I built - it took about four trys, but it finally started working - quite well I might add!
   / Dam Failure - Any Suggestions? #30
Does anyone have any ideas that might help us get out of this situation?
FWIW - If you decide to keep the pond, I would strongly suggest an emergency spillway be constructed to prevent the topping of the dam (no matter how much it rains) in the future. Do not rely on an overflow pipe only. The level of the spillway should be between the overflow pipe and the top of the dam.
Adams 6T Fertilizer Spreader (A55301)
Adams 6T...
Year: 2002 Make: Ford Model: Econoline Vehicle Type: Van Mileage: 156,145 Plate: Body Type: 3 Door (A51694)
Year: 2002 Make...
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
2010 Chevrolet Tahoe SUV (A52377)
2010 Chevrolet...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2021 Allmand Bros...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
