Loader Converting to skid steer attach on 20 series
   / Converting to skid steer attach on 20 series #1
hammick
Montana
LS MT357HC
Not a lot of info on converting my 4020 to SSQA. Mine is a 2002 model. I understand they now come standard with SSQA.
I don't want to use an adapter that adds weight and puts the bucket out farther. Are there any options for a straight conversion? If not, does Branson make blank plates that I can weld on to say pallet forks to use with the Branson quick detach system?
Thanks for any advice.
   / Converting to skid steer attach on 20 series #2
Can you provide a picture of what your system looks like now?
I'm picking up the tractor in about 10 days so I don't have a good photo but below is a link to a post and photo from a previous thread many years ago. The Branson QA is similar to Euro but different enough that Euro attachments don't fit (or so I've read).
http://www.tractorbynet.com/forums/century-branson/356600-bl20-quick-attach-type.html
My dealer can get a set of custom made forks that fit my Branson quick detach for $600. Lightweight at 225lbs. Done deal.
   / Converting to skid steer attach on 20 series #5
I ended up waterjetting new brackets, then welded them to my fork carriage. I almost built an adaptor to skid steer, then opted not to for the same reason. Now I have the blanks and extra 3/4" material to build anything else I need, although between the bucket and my forks, I don't think Ill need anything else.
   / Converting to skid steer attach on 20 series #6
Good solution I think, especially if you are fitting up just one more attachment like forks.
   / Converting to skid steer attach on 20 series #7
I had prematurely ordered a set of global/euro forks before my tractor was delivered, not knowing that the Branson quick attach was proprietary. I created a template and had these waterjetted. Came out great. I then cut off the brackets on the fork carriage I had, and welded these on.
   / Converting to skid steer attach on 20 series #8
We generally keep a couple sets of "Branson hooks" for just the same reason. It's a great system actually, but not universal unfortunately.
   / Converting to skid steer attach on 20 series #9
Hi Dave,
Do you still have any of the Branson Hooks that you would sell ?
Looking to build a set of forks.
Thanks
   / Converting to skid steer attach on 20 series #10
Hi Dave,
Thanks
I think everything we currently have on the shelf has been cut off of buckets when we converted same to SKC. So they are not flat on the back, they have a big notch where it wraps around the bottom of the bucket. We use them occasionally for the right application, but you would be better off to make a tracing of the bracket and go down to a metal place and have them cut you out a couple. With the right equipment, it is easy enough to do. We can burn you out a pair on our plasma table, but I doubt we would save you much if any after we have to ship them from the left coast to the right.
2015 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2015 Ford F-250...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
John Deere TX 4x2 Utility Gator (A49346)
John Deere TX 4x2...
Marliss Industries Grain and Soybean Drill - Selling ABSOLUTE NO RESERVE (A52128)
Marliss Industries...
2005 MACK GRANITE GU713 DAY CAB (A51219)
2005 MACK GRANITE...
SET OF 48" QUICK ATTACH MAST PALLET FORKS (A51242)
SET OF 48" QUICK...
