clemsonfor
Super Member
Where is that Dead horse smiley?
Cannot tell if you are being sarcastic or seriousIn either case, how is your post even the slightest bit helpful?
If you don't trust the braintrust at TBN, just call your dealer and ask them is Shell Rotella T6 in (whatever oil weight is available at Walmart) is OK to use. I would expect them to say he!! yes it is better than what is specified. I am sure the OEM manual doesn't spec full synthetic as required.kubota m7060 8 speed
unless i can get it in writing from kubota
This explains it well. Sometimes the OEM manuals are so out of date that what is specified in them is no longer available. As for 15W40, my Walmart usually carries Shell Rotella T6 full synthetic in several xxW40 grades. Get the one you want but the lower the W number the better it will function in cold weather. In hot or full operation temps, there will be no differences.
For West Monroe, La. you really wont need the 5W or 10W for cold weather since it rarely gets below freezing, but if it is the same price, why not go for the 10W40 or even 5W40? Check the Walmart closest to you and look at the Shell ROTELLA T6 (full synthetic) for optimum performance or the Shell Rotella T (no 6 on it) which is standard dino oil and will be much cheaper if you want to go that route. I think you will find 15W40 in both types.
I use the Shell Rotella T6 in everything I own, lawnmower, tractors, cars, motorcycles, 4 cycle boat engines etc. In my boat I noticed that I get about 200 RPM more using full synthetic oil compared to regular oil of the same weight.
