Just brought home my first snowblower
   / Just brought home my first snowblower #1
Soldier415
Vermont
2001 Kubota L3010GST. 2005 Kubota L3430HSTC
MK Martin Meteor SB68 on my Kubota L3010.
Looking forward to not having to rake gravel back up from both sides of our 1/4 mile driveway in the spring anymore.
The heated cab will be nice
   / Just brought home my first snowblower #2
MK Martin is a good machine. A suggestion - do a THOROUGH walk up & down your driveway & the shoulders before the first snow. You are checking for "objects" that can be picked up by the snowblower and thrown to a great distance or can damage the blower. Rocks, sticks, fence posts, dirt mounds etc,ect. At the bare minimum these can easily snap a shear bolt. Mice & gophers hiding in the berms, which will also be thrown a long way, are just part of the fun of a blower.
Good advice, thanks.
The driveway currently has a high crown/ridge in the center. I was thinking I should get out there with the box blade and flatten the road before the first snow. Thoughts on that?
   / Just brought home my first snowblower #4
My neighbor just came across a huge old cast iron roller. My tractor cannot lift it so thinking about a ton and 5 feet wide. Before snow when my driveway is wet I am going to roll it. Should take care of any small stones sticking up.
   / Just brought home my first snowblower #5
Ahhhhh - I would probably NOT want to flatten the driveway. The high crown is what helps shed rain/water and keep the driveway from getting soggy. My biggest problem was waiting until my driveway froze up hard enough that the lip of the snowblower didn't dig up the gravel. My blower was only 60" wide so it took three passes to get the full width cleared. You know - up one side, down the middle and then the remaining side. Even with your new 68" wide blower - I bet it will take two passes, at least, to clear the driveway.
If, like me, you can't wait for the ground to get frozen & hard - - with the blower all hooked up, lower it to the ground, then shorten the top link until the front lip of the blower is 1.5 to 2.0 inches off the ground. This way you can blow snow to your hearts content and not risk digging up and blowing the gravel off the driveway.
Believe me, if that front lip digs in to your driveway - your snow blower will blow the gravel/dirt just the same as snow. The only difference is the discharge will be brown/black and it will sound like four marbles rattling around in an empty 303 tomato can.
   / Just brought home my first snowblower #6
Ouch!!!!! they did not put skids on it or sell skids for that snow caster?????
Your going to need a hard freeze before you can use it or pack down the
first couple of snowfalls for the first few inches of base to avoid problems.
I hope that they can sell you skids for it as the cutting edge even tilted back
by threading in the top link is going to dig.
   / Just brought home my first snowblower #7
I have the same the same snow blower and have a few suggestions. First paint the chute rotation handle orange or some bright color so you can see it easily when raising the 3pt. you don't want to hit your tractor with the handle. Next keep extra shear pins on hand until you get the hang of clearing your drive. Going too fast in heavy snow can cause a jam and a sheared pin. I use Fluid Film on the inside of the chute, auger and intake to help keep things "moving". MK Martin does sell kid shoes for this model if you need them. They were very responsive to my emails when I first started using mine. Enjoy it!
   / Just brought home my first snowblower #8
I finally noticed something on your new blower. Hard to explain, but--- the sheet of steel that forms the bottom of the blower does not extend out to the full extent of the vertical wings. Boy, I hope that makes sense. On the blower I had the bottom went from the outer edge of the vertical "cutter" on one side to the outboard edge of the vertical "cutter" on the other side. Leonz comment brought this to my attention. Tipping my blower back so the lip was 1" to 2" off the ground would have a much greater impact on not scraping up gravel than on yours. That's because the lip on your blower is further back - its actually behind the auger. The lip on mine was in front of the auger because this sheet of steel was much bigger, wider, deeper - whatever.
Anyhow - seeing what I see now - I would recommend that you obtain skids because tipping your blower back probably will not prevent digging.
   / Just brought home my first snowblower #9
Nice blower!
I'm going with the guys who suggested getting skid shoes. I'd be very surprised if they weren't optional, so I check with the manufacturer first.
I see you have a manual chute rotator. That's a bit of a hassle with with a cab tractor. I sold my Woods blower due to the manual rotator (replaced with a Frontier with hydraulics). Now, if you're in a situation in which you can set the chute in one direction while the tractor is warming up...a long straight driveway, for example; a manual chute isn't an issue. My drive isn't that long and is a loop, so I do need the rotation as I clear around the loop.
If you do want to go with hydraulics or electric chute rotation, try MK Martin first. If not available through MK Martin, there are aftermarket options.
While typing this...driveway markers are a good idea too. I definitely need them too! Invariably, I clear a an area that's half drive, half lawn! Better put markers on my list too!
Anyway, good luck with the blower. I'm sure you'll find blowing snow is a blast!
   / Just brought home my first snowblower #10
I made a set of skids for my 78" rear JRW blower out of 3.5" by 4" angle that bolts onto the sides of the blower. You can put these on for the first few weeks of blowing to help keep the blower elevated a little as you build up your frozen base. Driving on the first small snowfalls help make this base. Once the drive gets frozen, you can pull the angle off and go with the factory skids. Tilting the blower back a little at the start helps too, but remember to keep the PTO shaft angle less than 15 degrees while it is under load blowing snow. Depending on the winter and the weather you get, you will still run into soft ground at the side of the road occasionally. Clean, grease chain, and paint the inside of the fan/chute area each spring.... and ENJOY...!!!!! Here a picture of my blower with the added angle iron skids at the first of the season.
For those asking, yes it has skid shoes behind it
   / Just brought home my first snowblower #12
congratulation, looks like a great setup :drink:
Went out today to give it a good once over as I was in a hurry when I picked it up.
Get to the very rear and notice only four fan blades. The catalogue the salesman gave me when selling me on it shows all single auger SB series have 5 fan blades and it was a deciding factor in my purchase.
I'm guessing they are trying to pass an older model off on me, and frankly i'm pissed.
   / Just brought home my first snowblower #14
Four fan blades is a good setup.... a LOT better than three. The important thing is the fan diameter and depth. The blades are the shovels, longer shovels [ larger fan diameter ] throws farther. I personally have not seen any with more than four shovels .... :)
That may be so, but I agreed to pay for a blower that was marketed as having five blades, so I want what I paid for.
Called and spoke to the sales guy I worked with. He was surprised that it was a 4 blade as he has only seen 5 blade meteors. He is going to do some checking and call me back
   / Just brought home my first snowblower #16
I checked on their Canadian site and they state that all Meteor blowers are now made with five blades....... so you are right...
Five Blade Fan
All Meteor Snow Blowers now feature a standard 5 blade fan. The five blades not only evacuate high volumes of snow quickly, but also feature tighter tolerance to the housing increasing velocity of the snow exiting the chute.
MK Martin | Meteor - Pull Type
Just an update. Talked to the salesman I purchased the blower from. He is checking with their distributor rep to see when the new Meteors will be delivered. I plan to take this one back and get the correct 5 blade model.
He was very nice about the whole deal.
   / Just brought home my first snowblower #18
Couldn't hurt - although a box blade might not be the best tool - I'd give it a couple of passes with a landscape rake. I second the "pick up debris" advice. I live in rock country - I pick up everything bigger than a golf ball at least 5' past the edge of the driveway. Never broke a shear pin except when I ventured out into the road and picked up a boulder, or chopped the throttle while the blower was full of snow (don't do that - turns into concrete and breaks ALL of the shear pins).
I'll get some pics up of the road as it currently sits. I have a grader blade and landscape rake
Update: New 2016 Meteor SB68 is waiting for me at the dealership to exchange for the older one.
PALLET OF SCRUBBER PODS (A58214)
PALLET OF SCRUBBER...
2012 TEX MEX TRAILER LOW BOY GOOSENECK (A58214)
2012 TEX MEX...
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
UNUSED FUTURE EXCAVATOR COUPLER (A60432)
UNUSED FUTURE...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2023 GREAT DANE FLP-0024-00053 53FT FLATBED TRAILER (A59905)
2023 GREAT DANE...
