PTO Question
   / PTO Question #11
Might be beveled gears now.
Is the detent in place? And how much gear, spline engagement. It might have been run with thrust play by a prev owner till it was 99% gone, and then he fixed thrust play, but not coupler. Gas forward and it simply might not have enough meat for positive engagement.
   / PTO Question
I am thinking I will need to pull the top cover to get a good look at the detent, right? I think that will also give me a look at the gear/spline engagement?
   / PTO Question #13
better than side cover anyway.
   / PTO Question
I will tear into it and let you know what I find. Thanks for the help.
   / PTO Question
I think I found the problem. The coupling is worn on the transmission side. It also looks like the splines are worn on the output shaft coming from the transmission. I have attached a couple of pictures. What are the chances that a new coupling will solve the problem? I hate to think about replacing the output shaft, that looks line quite a job.
   / PTO Question
View attachment 484748View attachment 484749
Additional update:
Upon digging a little further, the shifter fork had extensive wear and was bent not allowing the coupling to fully engage. The coupling will slide onto the countershaft easily and fully with the fork removed. I will replace the coupling and fork. I think that should do the trick. Will report back with results.20161016_114100.jpg
   / PTO Question #17
Yup, poor engagement leads to the spline wear.
   / PTO Question
New coupling and shifter fork made all the difference. Ran the finah mower and my new (to me) old flail mower for several hours today without one problem. I am still scratching my head as to how the fork could have bent so badly. Thanks to all for your help.
Ike
   / PTO Question #19
Seen it happen. glad you got her fixed.
2025 Unused LandHero LDH-T460XX Mini Skid Steer (A52377)
2025 Unused...
2015 Ford E-350 Cutaway Van (A52377)
2015 Ford E-350...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51247)
2016 KENWORTH T270...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
