Newly installed grapple freezes up
   / Newly installed grapple freezes up #11
Did you try reversing the two hoses that connect the tractor to the grapple valve? :confused:
I did with the same exact results. Is there really an in/out on these?
   / Newly installed grapple freezes up #13
I can't imagine there is. Reverse hoses and it goes backwards i.e. opens when you want to close.
   / Newly installed grapple freezes up #15
That's what made sense to me.
To the cylinder it does not matter,,,
but, from the hydraulic supply (tractor system, or separate pump,,, etc,,,) to a valve, it absolutely matters.
Supply oil to a valve outlet,, the valve will feel like it is locking up.
If the system is open center, and the grapple valve is not power beyond equipped, there can be an issue with that,,, also.
   / Newly installed grapple freezes up #16
I guess I forgot to ask if the remotes work with anything else?
My question about reversed hoses applies only to the hoses going to the valve that controls the grapple.
The remote valve may be connected to the tractor incorrectly.
   / Newly installed grapple freezes up #18
Also could be mismatched couplers.
It wouldn't work for 30min straight and then act up would it? It shouldn't work at all right? I don't have any other implement to try out on it. I got new couplers today and will swap them tomorrow.
   / Newly installed grapple freezes up #20
Could it have trapped air? Or maybe even water or something that would act differently hot?
2012 Ford E-150 Passenger Van (A51692)
2012 Ford E-150...
33ft Dovetail Flatbed Trailer (A53473)
33ft Dovetail...
JOHN DEERE 9650 COMBINE (A51247)
JOHN DEERE 9650...
Jack Daniels Sign Decor (A51694)
Jack Daniels Sign...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
JOHN DEERE 1705/6700 (A53084)
JOHN DEERE...
