generator hook-up question
   / generator hook-up question #1
MattEffinCameron
New England
B2920
We bought a house a few years ago that has a pre-wired generator hookup outside the garage (but no generator).
There is a barn about 100' from the house. The house has 200amp service and the barn has a 100amp panel which is wired off of the main house.
Is there any chance if I had an electrician come out, I could just add a generator hookup in the barn so as to run a PTO generator on my new tractor while protected from the elements (and not as close to the house)?
   / generator hook-up question #2
To be legal and safe, there would have to be some way to ensure the house was disconnected from the grid when the generator is used. I don't know how it could be done. Relying on the user to disconnect the grid probably would not satisfy the typical bureaucrat.
The wiring should be adequate if the generator output cannot exceed the 100 amps the barn is probably wired for.
   / generator hook-up question #3
It is possible, but not super easy. If you can feed the generator into the barn panel, there is no easy way to have the 100 amp barn feed "know" if the generator is active. Also connecting the generator to the barn when there is power would blow a breaker of blow out the generator. The "best" option is a separate line from the barn to the house with a 200 amp transfer switch at the house, or a separate feed breaker with a mechanical interlock to the main breaker at the house.
The cheap and dirty way is to feed into the barn panel only AFTER the main at the house is turned off. This would not be code, and care must be used to insure that when the generator is connected, the main is off. I have seen systems used (in industrial applications) that use locks with one key. One lock is on the main at the house. Turn it off, lock it out and remove the key. The same key is then used to unlock and enable the feed breaker at the generator. You could try to improvise something like this that might pass muster.
carelessness can either fry your generator or fry a lineman working on the outage.
Paul
   / generator hook-up question #4
Used one of these on my load center:
National Ram Electronics
Maybe that will help. Tying in at your barn will only decrease the amount of juice at the house. Think loooong extension cord.
   / generator hook-up question #5
Just make sure to have a TRANSFER SWITCH so to separate and isolate the generator from the power grid electricity. If not, you can have a serious fire or result in electrocution/death.
   / generator hook-up question #6
As previously stated the best solution is the supply line from the shed to the transfer switch.
   / generator hook-up question #7
Paul
YES!
Its called a Kirk Key.
There's a discussion about it somewhere here on TBN.
In a nutshell, you have to turn off the main power, remove the key, take it to the remote location where the generator is, install the key and turn it, then turn on the generator power. You cannot accidentally back-feed the electric grid with this setup.
Do some research on it. It may be what you're looking for. It seemed like a simple and elegant solution to me.
   / generator hook-up question #8
No, that's not the best solution. The best solution is the legal, safe, cost-effective, convenient, least expensive and least disruptive to the owner that has to pay for it. We've had this discussion several times here on TBN. The kirk key will be the most cost effective best solution method in this situation.
   / generator hook-up question #9
I hadn't heard of the kirk key. It sounds interesting. In the case of the OP how does it ensure the house master breaker is disconnected before the generator is activated?
   / generator hook-up question #10
As I understand it, you cannot remove the key until the master is disconnected.
Once the master is disconnected, you remove the key, take it to the generator location, insert the key, and then turn on the generator disconnect.
Its impossible to have both on at the same time. Its on-off-on. Elegant solution... :thumbsup:
Tote Tank (A50860)
Tote Tank (A50860)
2016 New Holland B95CLR Loader Backhoe (A50860)
2016 New Holland...
2006 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2006 Toyota Tundra...
2016 Ottawa Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, 33,000 ... (A51039)
2016 Ottawa Yard...
2014 Chevrolet Impala Limited Sedan (A48082)
2014 Chevrolet...
2017 Ford Taurus SEL Sedan (A48082)
2017 Ford Taurus...
