Septic Pet Peeve
   / Septic Pet Peeve #91
Mate, I haven't claimed anything; I stated a personal fact. No maybe about it.
I did state that I have a separate grey-water field, so the only thing that goes into my septic tank is human waste and bumwad.
One thing you do have going for you, by the looks of the vegetation, you are located in a year round warm region. Anaerobic systems love it when it's warm!
And I'm not "claiming" anything either, just stating fact.
And for those praising the aerobic systems.
In this area, they are not approved, and take "special consideration and engineering".
Plus, the word is they can be extremely fragile. That is the bacterium need a constant supply of "food", and the colony can collapse with a disruption such as a guest sending something "different" down the pipes. I'm not sure of the recovery process, I'm sure it is case by case, but I've "heard" it can take weeks to recolonize an aerobic system. That and a multi day power outage can do in the entire bio-system. It seems that the aerobic systems have pitfalls that make the possibility of smelling methane trivial.
The "SludgeHammer" appears to be marketed as a remediation adjunct. Not as a 20 year solution. Perhaps additional reading of the sponsor page is warranted.
   / Septic Pet Peeve
You are wrong. We will have to agree to disagree. Aerobic systems are found in ALL water treatment plants. It's the only way to properly and quickly treat millions of gallons of waste.
It also does NOT take weeks to establish aerobic bacteria.
You also miss the fact and point that aerobic systems also create turbulence and break down toilet paper and waste through the turbulence. That doesn't take place in anaerobic systems. Everything sits there and decays very slowly. Methane as a by-product also destroys concrete septic tanks over time.
   / Septic Pet Peeve #93
Anything new-fangled takes time to gain acceptance, and that will not happen uniformly.
Around here, they are mandatory in a few places, highly encouraged in others. Maryland has an official program to encourage their use because of the Chesapeake watershed issues.
   / Septic Pet Peeve #94
Municipal plants have a steady supply of "food stock", and full time operators keeping tabs on just about every aspect. If your up for a full time position, Go for it. Just don't be disappointed when the bugs give out on you while on vacation.
Besides, What is the hurry? I have no desire to see the waste water again at any time.
I do feel aerobic systems are a very useful tool when final ground filtration is not an option. My self, I would go for a conventional anaerobic separation tank with aerobic spray/ trickle system filtering effluent though "engineered medium" in place of the anerobic leach lines. There are some interesting designs out of Canada, some making use of what other wise would be waste plastics ;-) I do hope such systems gain acceptance here in the States.
Turbulence does not "break down" cellulose fibers. "Disperse" (break up?) may be the term you are looking for.
One should try not confuse the mechanism, Biological action is common to "break down" cellulose. (read: liquify or gassify). What you describe as "decay".
Chemical action and pyrolysis are not well suited to the task in discussion here.
Turbulence does speed things up however. (Exposed surface) The paper I use hardly holds together to perform it's assigned task. ;-) It doesn't stay intact thought the flushing cycle, that I am sure of! ;-) Perhaps there is an avenue for overall domestic improvement through conscientious selection of tissue.
As to methane destroying concrete tanks over time. How much TIME?
Let's just say there are various qualities of concrete.
I sense that you are quite invested in your position regarding the aerobic systems. Good for you, Such a noble subject to be committed to. I also note that there is nothing in my post to be "wrong" about. Unless one can err by saying "can", "the word is" and "I've heard" . tisk tisk.
   / Septic Pet Peeve #95
Talking SH-- about sh--. LOL
   / Septic Pet Peeve #96
From a quick google search I am gathering Cottonelle is about the worst and Scott about the best toilet paper in regards to septic tank breakdown. Comments?
   / Septic Pet Peeve #97
When we moved out to our farm in the mid 90s, we were not required to install a septic system or have an inspection or anything of the like. This was due to a farm exemption, which at the time was anything over 10 acres. At the time, we were (and largely still are) poor, so I installed a system myself consisting of a 500 gallon concrete tank and about 200' of lateral lines in gravel covered with dirt. We lived there for 11 years and never had any issues (this was a family of four).
When we built a new house on the same farm, our state ordinances had changed in that prior to have electricity connected to a new house, you had to present proof of a septic system inspection. So we had a new system installed - a 1200 gallon tank and about 300' of lateral lines. That was about 10 years ago and we haven't had any problems.
I've got no problems with ordinances regarding septic systems, but I do find some of them hilarious. Our septic system field is in a portion of our property that is also cattle pasture. I would guess that on any given day, one of our cattle expels more waste directly on top of the ground than the whole family does. I know that we don't need to have an open pipe running into a ditch as a system, but at the same time, I see exactly that from the cattle and all the wildlife in the area.
Good luck and take care.
   / Septic Pet Peeve #100
Well, Wouldn't you know, The Ultimate solution!
WORMS!
Worms for Leaching Fields (Septic Drain Fields) - All About Worms
And I read that Australia is leading the way is this advanced technology.
It's no wonder I haven't had waste water problems, The drain lines are under a flower garden that is just thick with night crawlers. ;-)
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
2011 FORD F-450 (A52472)
2011 FORD F-450...
Hr:8,875 vin:316000649 (A53421)
Hr:8,875...
2016 CATERPILLAR 325FL EXCAVATOR (A52705)
2016 CATERPILLAR...
