Anybody try a ESAB Rebel?
   / Anybody try a ESAB Rebel?
235 will likely be built off the 252 platform, so probably 220 only, rather than 120/220 capable.
I had a 252 a while back it was a pretty good unit. However the 235 is definitely a inverter unit, so it'll be a new design. That said, I don't mind if it's 220 only, but I would like for it to have a tig gas valve.
   / Anybody try a ESAB Rebel? #12
Thought the Fabricator 252i was an inverter based system:confused:
Looks like the fabricator might be. It appears they've had several machines with the 252 number over the years and I was thinking of a different one.
   / Anybody try a ESAB Rebel? #14
235 is a dual voltage system.
   / Anybody try a ESAB Rebel? #15
According to ESAB REBEL™ 235ic WELDERS OFFER UNBEATABLE COMBINATION OF POWER, PORTABILITY AND PERFORMANCE | SEMA Show looks like the 235 is 120/240v
Unmatched Portability and Multi-process Performance
At 53 lbs. and with a 235-amp rated output at 40% duty cycle (maximum output is 250 amps/30 volts), Rebel 235ic has the best power-to-weight ratio in its category, allowing users who need maximum flexibility when moving a welding machine around the shop or working in the field. The machine automatically detects the correct single-phase input power from 90 to 270V. Rebel 235ic comes wired with a 230V plug; users simply need to attach the supplied power adapter to connect to 120V power. Rebel 235ic holds 4, 8 or 12 in. wire spools, features dual gas ports with solenoid valves and has optional single- and dual-cylinder carts, remote amperage controls and spool guns for MIG aluminum.
   / Anybody try a ESAB Rebel? #16
Sounds Great, I know the other Rebel. I don't know the 235i. I did look up the price..I'd buy a Miller or Lincoln at that price. Just sayin. ESAB is a dying ember. IMHO.
   / Anybody try a ESAB Rebel? #17
Yomax, that is not a very strong endorsement. I thought ESAB was doing quite well when they bought out Victor and Thermal Arc...they certainly seemed to be doing quite well.
   / Anybody try a ESAB Rebel? #18
$2600 is getting up there, but what Lincoln or Miller would be in that category? Street price should be about $2300, based off the 215ic.
   / Anybody try a ESAB Rebel? #19
I thought I saw a advertised price of around $1800 for the 235, but I could have been wrong.
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATE (A54757)
UNUSED LANDHONOR...
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
2017 Nissan Versa SV Sedan (A53424)
2017 Nissan Versa...
UNUSED LANDHONOR MAP-16-24W MINI MOUNT PLATE (A54757)
UNUSED LANDHONOR...
2006 Chevrolet Silverado 1500 4x4 Pickup Truck (A53422)
2006 Chevrolet...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
