Kubota GR2120 diesel - 2016 Cab fabrication
   / Kubota GR2120 diesel - 2016 Cab fabrication #12
That is freaking cool man. nice work. Following.
Hi, here is cab progress update#5...,I put the first base coat today, had a little bit of hard time with the paint cause it was windy and cold today but... it's only the first coat and lots more coat to come and sanding between coats:dance1:
   / Kubota GR2120 diesel - 2016 Cab fabrication #14
Looking good. Give that paint time to cure well if your sanding / buffing between coats.
Hi everyone,... here is my cab progress update#6..., cab is all painted and as I said in my last post... it was a challenge painting the cab is this weather and time of year:rolleyes:...but I'm satisfied of how it came out:), the cab is all finished except of the heater and some electrical stuff like lights and fuse box ect..., still waiting for some parts from china to arrived :confused2:, will post a final update with more pictures from outside and inside the cab and a video of daytime and nighttime showing everything working like wiper ,lights ect..., once again thank you everyone for your interest, compliments and kind words of my work :cool2:.
   / Kubota GR2120 diesel - 2016 Cab fabrication #16
You have done a fabulous job the time and care you've put into sure shows !!! :thumbsup:
   / Kubota GR2120 diesel - 2016 Cab fabrication #17
Great workmanship .
   / Kubota GR2120 diesel - 2016 Cab fabrication #18
I second that! It came out very, very nice!!
   / Kubota GR2120 diesel - 2016 Cab fabrication #19
Very nice job! I have used my GR2120 and snowblower for 2 winters now, getting ready for 3rd. 4WD is awesome, I do not even use rear weights. Get a bag with bolts and locknuts (2 different sizes) and short handle wrenches, you are good to go! The auger takes a special cut Kubota bolt. For the fan, just use a standard hardware bolt grade 5 bolt. Philip.
   / Kubota GR2120 diesel - 2016 Cab fabrication #20
Dude, that is incredible.
RoGator RG1300C Air Max Precision 2 Spreader (A53342)
RoGator RG1300C...
1999 KENWORTH T800 DAY CAB (A53426)
1999 KENWORTH T800...
3500# TANDEM BRAKE AXLES (A51248)
3500# TANDEM BRAKE...
Quick Attach EZ Axe Skid Steer Tree Shear (A53472)
Quick Attach EZ...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
